I Hate This Dual Mass Flywheel - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #21 of 35 (permalink) Old 03-27-2015, 10:47 PM
I don't think my gripe is just with the clutch. Getting started smoothly in first gear is tricky--as others here are remarking--but it seems that even after the clutch is fully engaged, as the engine revs from about 1500-3500 rpm, there's an unevenness to the acceleration--a slight lurching, hesitation--that is annoying. 2nd gear is similar, but not as noticeable. 3rd through 6th are fine; very nice actually, every bit as good as the manual on this car is hyped to be. Does anybody else have the same experience?
mcbru likes this.
bd525 is offline
post #22 of 35 (permalink) Old 03-28-2015, 04:33 PM
The shifts are no problem when I take off at high speed. But in day-to-day driving, particularly in traffic, I also tend to face challenges. (Fluids and everything checked.) After 5K miles I think I am getting used to the shifting. For me, the smoothest way to go from 1-2 and avoid crunch is to shift slowly and hesitate slightly before the throw. Third, however, goes in more smoothly on a quick throw. Also, 4th goes in better at a higher RPM. Only 5th and 6th go in smoothly all of the time. So go figure. It's a fussy car.
rrocks is offline
post #23 of 35 (permalink) Old 04-19-2015, 08:53 PM
Quoted: 16 Post(s)
I notice the unevenness you mention occasionally, but it's fairly mild. Not a transmission issue so much as a fuel or programming one, it seems to me (or both since the drive by wire is all computer controlled).
6speeder6 is offline
post #24 of 35 (permalink) Old 04-19-2015, 10:40 PM Thread Starter
solar365's Avatar
Quoted: 741 Post(s)
Groaned at 6 Times in 6 Posts
Yes, there is a setting in the ECU that retards spark a bit after the shift. 1st revs so quick the result is a hesitation after the shift followed by the spark timing coming back forward just as the car gets into the meat of the torque band.
The result can be synchronized headbanging for driver and passengers, whether you are listening to death metal or opera.
It also exacerbates the slowness of shifts of a MTX during routine driving vs all the cars around you with ATX.
OVT was able to turn that off with the tune thank goodness.
Flowmaster dBX Exhaust---Corksport SRI W/Cold Air Box---OrangeVirus Tuned ECU---90lb Weight Red.---Shifter Mods
solar365 is offline
post #25 of 35 (permalink) Old 09-19-2015, 09:18 AM
Insight's Avatar
Quoted: 10 Post(s)
welp.. I might be one of the first to actually get eyes on the flywheel. My clutch is gone at 25k and the dealership says that I have to prove that its a Manufacturers error for them to fix it at no cost. otherwise it is going to cost me $1500+. I'm waiting till Monday to call Mazda North America, maybe they will hep me out.
If I end up doing this myself I would prefer to replace the flywheel with a single mass.
Anybody know if one is in the works?
Insight is offline
post #26 of 35 (permalink) Old 10-02-2015, 06:54 PM
Quoted: 9 Post(s)
I know this is an old thread but I am glad I read it as it explains that weird 'bang' I've gotten a few times when shifting at slow speeds. Driven sticks for decades and never had that happen any other car.
That said...I don't think anyone should be getting 'crunch' with this transmission. Maybe a little notichiness is normal but not crunching. I'd recommend changing the fluid on the tranny to Motul or Redline or similar full synthetic somewhere around 3-5k miles. I just came out of a Scion FRS which while a great MT owners were experieincing crunch, notichiness and hard shifting with the factory fluid. Many changed up to full synthetic after a reasonable break in period and got much better results. Also fwiw, that was an Aisin tranny and the OEM also spec'd the obsolete GL4 fluid...but the latest GL5 synthetics smoothed out shifts and no one has reported any issues. I had the dealer Ok the Motul GL5 and change it for me (just in case). I'm planning to do the same with the 6 once I hit 5K
JetBlack6 is offline
post #27 of 35 (permalink) Old 10-02-2015, 08:54 PM
Caliche's Avatar
Quoted: 97 Post(s)
I'm starting to think part of it is how we enthusiasts like to drive (spirited) and shift fast. So, my wife has not driven a stick shift since 2001. She was claiming she had 'forgotten' how to do it after so long, and she was afraid (huh? "You don't forget those things", I said, "is like riding a bike!"). Anyway, last Saturday we went out to brunch and I had one too many cocktails for so early in the day, so I told her "guess who's driving home?" Well, lo and behold, she did, and she drove like she had never stopped driving a manual tranny. Now, she drove at speed limits in suburban streets, not spirited at all, but the car never hesitated, hopped, nor crunched, grind, skip, nothing, zip, the whole way. I couldn't believe it. Her shifts were slow to normal throws, and she handled the clutch just fine. I was again like "huh? Wtf?"
Caliche is offline
post #28 of 35 (permalink) Old 10-03-2015, 05:57 PM
Quoted: 29 Post(s)
Its funny you say that cause I've had similar experiences. These cars are easy to learn stick/clutch on for some reason. But those of us who already have expectations for how a shifter and clutch should feel have problems with it.
Another example, I'm sure all you guys have driven cars with mechanical throttle cables, and at least occasionally done full throttle shifts. When accelerating hard in the 6 or any car with an electronic throttle, I always forget to lift the accel before going for the clutch, instead of doing them more at the same time. I end up making the engine over-rev when the throttle's input lag thinks i am still flat-footed. I've had this car for a year and a half now and I still havent gotten that motion subconscious, because im still used to how throttle cable cars drive.
Is there a more specific name for this spark retarding you're talking about? I'd love to get OVT to turn it off but I wanna make sure I am asking for the right thing.
2014 Mazda6 Sport with 6-speed
- Koni Sport Dampers with H&R Springs
- Morimoto 4500k HIDs
2001 Miata Project (blown engine)
mcbru is offline
The Following User Says Thank You to mcbru For This Useful Post:
Caliche (10-03-2015)
post #29 of 35 (permalink) Old 12-26-2015, 05:47 PM
Cruelkix's Avatar
I just bought my 2015 Mazda6 1 month ago and have been wondering if I just wasn't getting the hang of the clutch yet. Happy/not happy to see I'm not alone. Now that I think about it, I've already started to adjust my driving style to really non agressive until I am 100% sure I'm in gear fully. I'm enjoying the car a lot., but that Dual Mass Fly Wheel seems to really screw with my style of driving.
I'd also like to hear about more about this OVT ECU change. Can someone point me in the right direction?
Cruelkix is offline
post #30 of 35 (permalink) Old 12-26-2015, 06:18 PM Thread Starter
solar365's Avatar
Quoted: 741 Post(s)
Clink the second link in my signature for the thread on it. Also google OrangeVirus Tuning to find their website.
Cruelkix likes this.
solar365 is offline
