Steering wheel/column rattle... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 03-28-2013, 09:22 PM Thread Starter
2006_MS6's Avatar
Quoted: 338 Post(s)
Groans: 15
iTrader: 4 reviews
Red face Steering wheel/column rattle...
I have a rattle coming from the steering wheel/column. If I push or pull fairly hard on the steering wheel it will stop.
Anyone else have this? If so, how did you fix it?
2018 Charger Hellcat
1999 Corvette - Vortech 623 WHP
2004 Acura TL
2006 MAZDASPEED6 GT #3557 - SOLD!
2007 MAZDASPEED6 GT - SOLD!
2006_MS6 is offline
post #2 of 7 (permalink) Old 03-29-2013, 01:16 AM
Gujustud's Avatar
Is it a knocking sound? If so, you need to get your steering column greased up. I just had it done last week and the sound is gone.
Gujustud is offline
post #3 of 7 (permalink) Old 03-29-2013, 08:21 AM Thread Starter
2006_MS6's Avatar
Quoted: 338 Post(s)
Groans: 15
iTrader: 4 reviews
Not a knock. It sounds like your typical plastic interior rattle.
2006_MS6 is offline
post #4 of 7 (permalink) Old 03-29-2013, 08:52 AM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 621 Post(s)
Groaned at 8 Times in 8 Posts
iTrader: 2 reviews
My steering wheel rattle was the horn/airbag cover. It was making contact at the top left corner by the audio controls, and could be stopped by either applying pressure to or lifting up on the top left corner of the cover, and even simply sliding something like a business card in there would stop it by preventing the contact.
Mine only did it at idle with a 900 rpm idle and BSD, but it was loud as hell and hyper annoying.
I had intended to remove that center cover and either insulate or remove the offending bit of plastic. Win for me tho as my K04 seals gave up before I got around to it, and with the BNR in and smoking no longer a concern I was able to return my idle to sock values and the rattle went away.....
FWIW tho, for weeks I thought the sound was coming from behind the dash or from the steering column because I could put enough pressure on the wheel to make it stop. It was by accident that I found the cover to be the culprit.
HTH
1and1
TiGraySpeed6 is offline
2006_MS6 (03-31-2013)
post #5 of 7 (permalink) Old 03-29-2013, 12:35 PM
MaKeH's Avatar
Quoted: 41 Post(s)
mine squeaks when the car stays in the sun... donno where to look for lubricating :-)
2004 mazda 6s wagon/ nautilus headers/mf cat back/tb bypass/tb spacer/ k&n CAI/red painted callipers+mazda sticker/ AWR lower engine mount 70duro/b&m tranny cooler/magnetic tranny filter/v-power ngk plugs/55w HID/7k angel eyes/ all interior white LED bulbs/EGR reroute mod/DD metra kit-Clarion NX602 HU/ back up camera /IM spacer/M Milan engine swap/grounding kit
MaKeH is offline
post #6 of 7 (permalink) Old 03-31-2013, 06:21 PM Thread Starter
2006_MS6's Avatar
Quoted: 338 Post(s)
Groans: 15
iTrader: 4 reviews
HTH
Like I said on MSF, that was it. Thanks for the tip.
2004 Acura TL
2006_MS6 is offline
The Following User Says Thank You to 2006_MS6 For This Useful Post:
TiGraySpeed6 (03-31-2013)
post #7 of 7 (permalink) Old 12-28-2013, 09:14 AM
NoVaSpeed6's Avatar
Quoted: 41 Post(s)
how would I go about taking off the airbag cover? The rattle I have almost sounds like there's a loose bit of plastic bouncing around underneath the cover. It is very very annoying
NoVaSpeed6 is offline
