Do any of you use one of those self serve coin washes? After some experimentation, I found this to be the most effective way to clean your car.
1. Use wax wash to spray down the entire car. Try to get all the grit off your paint
2. Use the foam brush and spray the car wash soap into a bucket. DO NOT use the foam brush on your paint.
3. Use a couple clean microfibre rags and carefully wipe down the whole car. Take your time with this step to ensure the wax seals a good layer on your clean clear coat. Do not use a swirl motion to avoid swirl marks. Flip, fold, scrub and squeeze the rags often to ensure you’re not scraping grit into your clear coat. This is especially important with you people that have darker paints which show imperfections easily.
4. After the car is covered in soap, give it one more rinse with the wax wash. All this wax you using will build a layer on your clear coat which keeps your paint always looking fresh and reduces the frequency that you need to wash your car. Once you get a layer of wax on your car, any grit just comes right off so you don’t need to worry about scratching your clear coat when you are wiping everything down.
You have the pay for the coin machine system twice to do this properly, but it’s still half the price of an automated car wash and your paint will look amazing after you build a layer of wax on your paint. You will reduce rust and keep your car looking fresh for a very long time
For the interior, all you really need is a light detergent or interior detailer to clean everything, including the seats. The seats have a protective coating on top of the leather so don’t bother wasting your time “conditioning” the leather, because it’s not getting past the protective layer. Use a soft horsehair bristle brush to scrub the solution into the seats. You can also hang up the interior carpets on the wall at these self serve places and give them a good clean with the pressure washer... you will be amazed at how clean the mat looks afterwards and how much grit came out. Just be sure to give them a good couple whacks against the wall before you put them back in your car and once you get home, allow them to fully dry overnight somewhere ventilated to avoid bacteria buildup in your car.
A cheap, and effective way to keep your car looking fresh for those of you who gotta do it themselves. Just be very careful with your clearcoat when wiping down the car.
Cheers
Cheers
