Touchscreen Overtemp!?! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 11 (permalink) Old 07-21-2016, 03:58 PM Thread Starter
Mr. Dingleberry's Avatar
I got in my car yesterday afternoon to drive home from work and before the safety warning had a chance to display, it popped up with a notice that the screen was too hot, and may not function properly. I have an hour commute, so I thought it would cool as the A/C ran. Ten minutes later, the same message popped up again. Thirty minutes into the drive (car has been running the entire time), the system rebooted. According to the console, outside temp was running 100-103 degrees.
Just got off the phone with the dealer, and all they know to do right now is check the software version. Unless the updates changes the temperature parameters, that won't fix it. Surely Mazda did full solar load testing on this design before deciding to stick it on top of the dash... It's the same location in the Miata, and it stands to suffer more direct sunlight.
Current Vehicles:
2016 Mazda6 Touring
2002 Honda Civic EX (wife's)
2000 Toyota 4Runner Limited (Family hauler)
1999 Toyota Tacoma Base 2WD (For my oldest son)
1991 Toyota 4Runner SR5, 3.4L engine swap, 33/12.50R15, 4" lift, geared to 4:88 with factory E-locker in the rear and Detroit locker in the front.
Mr. Dingleberry is offline
post #2 of 11 (permalink) Old 07-21-2016, 04:21 PM
Stephen Snow's Avatar
Quoted: 9 Post(s)
Hmm, mine did this once when I left the cover on the sunroof open and forgot to put up my windshield sunscreen while at work. However, the warning only showed up once and I don't notice any loss in functionally.
This 100˚ weather does have me longing for remote start. You might want to invest in a good windshield sunscreen, it does help tremendously!
Stephen Snow is offline
post #3 of 11 (permalink) Old 07-21-2016, 04:52 PM Thread Starter
I'm in the market for one now...but it shouldn't need the shading. I'm in East Tennessee, and we don't really get stupid hot...we have high humidity and that makes it feel worse. But for people in Sante Fe or Phoenix, or even you in OKC; you guys see air temps of what, 120+? Take a thermometer out and put it in your car on one of those days and see what it says.
FWIW, it's a black on black car, and I'm getting the windows tinted soon...
Current Vehicles:
2016 Mazda6 Touring
post #4 of 11 (permalink) Old 07-21-2016, 05:10 PM
Quoted: 167 Post(s)
Groans: 9
My car sits out in the elements 24 hrs a day/365 days an year. I try to use a sun screen as much as possible, but that doesn't stop the car from heating upto 105 degrees by evening commute. A coworker has a Tesla, and is pretty mental about keeping the temperature inside his car low so he does not have to overwork the battery. He got a huper optik on the windshield, and claims it keeps the car 20 to 25 degrees cooler. It does have a mild blue hue though, and i would be worried if a cop spots it.
MilR is offline
post #5 of 11 (permalink) Old 07-21-2016, 06:10 PM
Quoted: 9 Post(s)
Here in OKC it easily stays above 100 during this time of year and the sun can be pretty brutal. One reason I went with the parchment interior, it actually does stay considerably cooler than black. Tint is a must here and the sunshade I purchased is one of the best I've owned.. Picked it up on amazon, here's the link. It fits around the sensor array in my 2016 GT with Tech perfectly. Though it sounds like you may not need one so heavy duty.
post #6 of 11 (permalink) Old 07-21-2016, 07:00 PM
rjhornsby's Avatar
Quoted: 131 Post(s)
The inside temp of a car on a moderately warm (it's somewhat also about being sunny than it is just warm) day - after just an hour - can easily reach 140F[1]. Easily. It wouldn't surprise me one bit for a car sitting in the sun all day in 100+ degree temps to reach into the 170s.
The electronics inside the display is only rated for a maximum temperature (typically around the 120-ish mark for consumer grade IIRC). When it exceeds that, it must shut down to protect itself. Otherwise components can melt and fry themselves. There are three issues: the components themselves are generating their own heat, which is added to how hot they already are from the ambient temp and the heat they've been absorbing all day, and they're having a very difficult time bleeding off all this heat like they normally could. The heatsinks and other measures aren't effective.
In the past, I've had my iPhone shut down after being indoors in the A/C all day when I tried to use it for more than a few minutes inside my hot car - even with the car A/C blasting. The plastic tray under the headunit (so not in direct sunlight) where I usually put my iPhone simply would not cool down.
Even putting the phone in the cup holder (where more cold air could reach) sometimes didn't do much good. It's simply the nature of consumer electronics - they're not built to withstand industrial heat tolerances.
I don't remember the exact numbers, so don't hold me to this, but IIRC the industrial type tolerant touch screen displays I used to work with for firetruck type applications were only rated to around 150-160F.
[1] How hot can the interior of a car get ? and how quickly? : HeatKills
rjhornsby is offline
post #7 of 11 (permalink) Old 07-22-2016, 08:58 AM Thread Starter
I used to work for a tier 1 supplier for a major automotive company. I worked in the test department where we did product launches, and even took a trip to Detroit to do on-vehicle testing in a climate chamber. The amount of testing that goes into a product is unreal (just look at this link Browse Standards on Exterior lighting : Topic Results - SAE International ) . They do design testing to make sure the plan will work in all aspects and aim to cover 90% of the market in how each component is used. I know Mazda is going to have done the same type of testing not just on the car, but on individual components as well. We did headlights and taillights at that company, and there were tests for solar load, which is to simulate the impact of the sun and extreme ambient temps. Most of this testing is to ensure not just the functionality of the part/system, but also the aesthetics as well (does the coating crack, bubble, flake, change color, does this thing still work? kind of stuff). We did a random vibration profile in 3 axis (vertical, front to back and side to side) for 8 hours in each direction while cycling a temp profile from -40 C to 80 C.
The good news is I went to see the dealer yesterday afternoon, and they are going to replace the entire unit. They had not heard of this problem and "called it in" to Mazda Corp. who advised to replace not just the touch screen, but the computer under as well. There were a couple other issues I discussed with them, but we will see how that pans out with the new computer.
Current Vehicles:
2016 Mazda6 Touring
The Following User Says Thank You to Mr. Dingleberry For This Useful Post:
rjhornsby (07-22-2016)
post #8 of 11 (permalink) Old 07-22-2016, 09:07 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2775 Post(s)
Glad the dealership treated you as they should have and you got a new unit.
The window tint will help tremendously and keep the car 15 - 20 degrees cooler on hot days - be mindful of the direction in which you park as well. Parking with the rear of the car facing the sun will not only save your dash/head unit, but your seats/steering wheel as well.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
rjhornsby (07-29-2016)
post #9 of 11 (permalink) Old 07-22-2016, 10:09 AM Thread Starter
I plan on getting one of these... https://www.amazon.com/Sunshade-Heat...+6+accessories ...and some window visors so I can crack the windows during the day. We have a lot of pop-up thunderstorms here in the summer due to the high humidity. I don't want to go home with a serious case of the wet arse.
rjhornsby likes this.
Current Vehicles:
2016 Mazda6 Touring
post #10 of 11 (permalink) Old 07-29-2016, 09:43 AM Thread Starter
No word back from the dealer yet on when the new system gets here.
Temps have been unbearable lately and yesterday we had a bit of a break with the high not reaching 90. That said, we had a bit of a shower right before I left and that cooled things off a bit.
I've said all that to say that on the way home, about 30-35 minutes of driving, the infotainment system shut down. The Mazda logo came up, then dimmed. It stayed that way until I pressed the home button on the console. It brightened back up and finished loading. No other issues. This may not be strictly temperature related. Either way, Mazda is replacing the system.
Current Vehicles:
2016 Mazda6 Touring
