MPG mystery solved, replaced by TPM mystery - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 12-08-2013, 10:28 PM Thread Starter
Quoted: 8 Post(s)
I had my oil changed and tires rotated at the dealer 10 days ago. Then I noticed a drop off in MPG. I checked the tire pressures today (I usually run 40psi front and 38psi rear) and the techs were smart enough to adjust the pressure after rotation. But they were now 30psi at all four wheels, not the proper 35psi spec on the door jamb and manual. No big deal, it happens. So I added 10psi to the front and 8psi to the rears but I forgot to reset the TPM button. I've been driving around all day (75+ miles) before remembering my failure to reset the TPM, yet NO warning light on the dash after this considerable differential in pressures. Does the monitor only detect decreases in pressure or what? Just wondering.
Westwood1 is offline
post #2 of 4 (permalink) Old 12-08-2013, 10:39 PM
tickerguy's Avatar
Quoted: 842 Post(s)
Groaned at 7 Times in 7 Posts
My understanding is that it's an indirect system (it works off the wheel sensors for ABS/TC rather than an absolute pressure transmitter in the wheel) so it will only detect differences between wheels. If the delta between where they were and where they are now was the same in all four or close to it the TPMS may not detect that.
BTW the indirect systems may not be as sensitive as the direct ones but IMHO they're superior because you do not have a consumable item (the sending unit) in each wheel which WILL require replacement and can require it at a time not coincident with a tire replacement as well, necessitating not only the expense but also the dismounting of tires when that would otherwise not be required.
tickerguy is offline
Westwood1 (12-09-2013)
post #3 of 4 (permalink) Old 12-09-2013, 02:20 AM
Quoted: 38 Post(s)
I've been driving around with my front right tire that has a nail in it and is leaking very slowly, so everyday I have to put air in it because the light keeps coming up. I'm putting off getting a tire because I just ordered rims and I'm trading this car in soon for a GT. But as far I know most of the time my tire pressure is between 20-30 and my MPG stays around 29 and has since I got the car
Beachhz is offline
post #4 of 4 (permalink) Old 12-09-2013, 06:04 AM Thread Starter
Quoted: 8 Post(s)
tickerguy, I agree that it is a superior system for the reasons you stated. I guess the 2psi difference in the rear was to small to detect (while I was thinking that the 8 and 10 psi difference was too large to ignore). Thanks.
Beachhz, I suspect that it would take more than one low tire to affect MPG. We had a three legged dog once that ran pretty darn fast too but he didn't have to eat any extra to do it.
