GPS mulfunction - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 16 (permalink) Old 09-05-2013, 08:00 AM Thread Starter
Quoted: 22 Post(s)
GPS mulfunction
Recently, I found my GPS not working properly. At low speed or stop, the GPS has random pointing. That means, when I stop at a red light, the car would suddenly think I was on the cross road or facing backward. This result in annoying rerouting or sometime freeze.
I upgraded the system in early July and the car is 6 month old with around 6k miles. Car parks in an underground lot.
Any idea to fix it?
leedstao is offline
post #2 of 16 (permalink) Old 09-05-2013, 08:59 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2776 Post(s)
Sounds like it's getting a mixed/weak signal and therefore is not sure which direction you're facing. Was it cloudy/overcast when this was happening, or were you in a remote area?
For the most part mine does not do this, but I do find that sometimes it's not quite sure which direction you're pointing because it's trying to predict where you're going and it can't.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is online now
post #3 of 16 (permalink) Old 09-05-2013, 09:43 AM
Quoted: 77 Post(s)
iTrader: 6 reviews
Any idea to fix it?
Do you have anything on top of your dash that could be blocking the GPS antenna? The roof antenna is not the GPS antenna.
2014 Mazda 6 Grand Touring Liquid Silver
Move.Over is offline
post #4 of 16 (permalink) Old 09-05-2013, 11:56 AM Thread Starter
Quoted: 22 Post(s)
I guess it is more like a random noise. When I drive on a straight road, my car icon in the NAV will move front and back it self. Sometime it shows me on a parallel road at least 50 yards away. When you stop, the speed shows 1 or 2 mph randomly also.
Further information, when the GPS goes wrong, it does show waiting for valid GPS signal in the center bottom.
BTW, The weather should not be the reason, I had this problem everyday for the past 1 month now and both in city and on open highway.
leedstao is offline
post #5 of 16 (permalink) Old 09-05-2013, 11:56 AM Thread Starter
Quoted: 22 Post(s)
Could you tell me where the antenna locates? Thank you.
leedstao is offline
post #6 of 16 (permalink) Old 09-05-2013, 11:59 AM
ForzaEsEs26's Avatar
Quoted: 122 Post(s)
It's behind the glove compartment I believe.
________________
ForzaEsEs26 is offline
post #7 of 16 (permalink) Old 09-05-2013, 12:02 PM
Shiro Shinobi
Byakuya's Avatar
That's odd then and certainly shouldn't be happening. I'd try backing up the software on the card and updating the firmware on the device. Since updating, I've noticed my unit acting a bit better and even the iPhone integration has been working much better.
Current:
, Sold:
, 3rd Generation
post #8 of 16 (permalink) Old 09-05-2013, 05:08 PM
Quoted: 32 Post(s)
The GPS antenna is under the center speaker grill on top of the dash. I know this for certain because I have already replaced my factory headunit for a different one.
GeraldEGB is offline
post #9 of 16 (permalink) Old 09-05-2013, 05:12 PM
Drizzoh's Avatar
Quoted: 335 Post(s)
Groaned at 8 Times in 7 Posts
Send a message via AIM to Drizzoh Send a message via MSN to Drizzoh Send a message via Yahoo to Drizzoh
Is the car not under warranty for some reason? Any problems with a car that new, I'd just bring it to Mazda and have them fix it for free. That is, after all, the point of a warranty.
Andrew |
Drizzoh is offline
post #10 of 16 (permalink) Old 09-07-2013, 07:14 AM Thread Starter
Quoted: 22 Post(s)
Called the Mazda and Tomtom today. Tomtom suggest a soft-refresh. Turn off the car and remove the SD card for 20 seconds. The same tricks as pull the power supply for your cable modem. Works fine at this moment.
leedstao is offline
