Quoted: 4 Post(s)
The TPMS can be reset using the button inside the car. I'd get your tires to the pressure you want, then hit the reset button.
Speaking of pressure...I measured my tire pressure after receiving my car (Touring, so I have the 19" tires). I got 39psi on 3 tires and 36psi on the 4th. Since Mazda's recommendation is 35psi, I reduced the pressure in the "overinflated" tires to match 36psi in all four tires. But I also see people posting about using higher tire pressures. What do people on here think the "best" pressure for these tires is?
Reason: Edited to mention that I have the 19" tires.
