how to connect laptop to my car? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 02-15-2012, 09:26 AM Thread Starter
Hi,
Please excuse my English
I would like to install a notebook in my car. (Mazda 6, 2003)
I have a problem with synchronization of the LCD monitor.
My laptop has VGA output (RGB + Vsync + Hsync)
I constructed this circuit: http://www.epanorama.net/circuits/vga2rgbs_ttl.gif
The output of this circuit is 4.5 volts and the output from the original DVD-ROM is only 1 volt. Resistive divider, I reached the required voltage.
The picture is still not yet.
Where can I find out resolution LCD monitor.
Has anyone solve it?
I hope you understand me.
tuliovb is offline
post #2 of 9 (permalink) Old 02-15-2012, 12:15 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2782 Post(s)
What kind of laptop are you using? Is it running Windows 7, and if so, is it x86 or 64 bit?
P.S. All this can be found by Right-Clicking "My Computer" (or if on Windows Vista/7) "Computer", and going to "Properties"
Let me know if you need any help.
Cheers
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #3 of 9 (permalink) Old 02-15-2012, 05:04 PM Thread Starter
I use windows XP
If I connect VGA output through my circuit to the display, picture on the display is doubled. It is doubled and between pictures is black belt. I tryed on 640x480 resolution
tuliovb is offline
post #4 of 9 (permalink) Old 02-16-2012, 12:35 PM
Shiro Shinobi
Byakuya's Avatar
Sounds like either your computer's graphics card doesn't know how to output the screen's resolution, or you don't have the right driver for it.
What kind of computer is it? If you can give me the model I can try to find out what's "under the hood" and how you can fix it.
Current:
, Sold:
, 3rd Generation
Byakuya is offline
post #5 of 9 (permalink) Old 02-16-2012, 12:48 PM Thread Starter
If I connect notebook to home TV, screen is OK.
graphics card: nVIDIA GeForce Go 7600.
tuliovb is offline
post #6 of 9 (permalink) Old 02-16-2012, 12:54 PM
Shiro Shinobi
Byakuya's Avatar
GeForce 7600 can handle that no problem...
If you right-click your desktop, there should be an "nVidia Control Panel" option, this will show you all the screens that are plugged in. If it's not there, look in the bottom right corner in the task bar, and there should be a green nVidia icon there to click on.
If it isn't there, you need the correct driver from here.
From there, you can customize how the card handles the output.
If there's nothing that fixes it, your problem might be the screen then. If the screen is looking for PAL input instead of NTSC then it will always show up odd like that, or the other way around.
Let me know what happens
Current:
, Sold:
, 3rd Generation
Byakuya is offline
post #7 of 9 (permalink) Old 02-16-2012, 05:44 PM Thread Starter
I changed resolution on the secundary monitor (car LCD) in the program Power Strip.
Except resolution, I try to change horizontal frequency view too from 5kHz to approximately 50kHz, but it didn't be successufully.
I think, problem is in the NTSC and PAL.
tuliovb is offline
post #8 of 9 (permalink) Old 04-27-2012, 05:40 PM
if you find a way make a guide would be useful for others
fitos is offline
post #9 of 9 (permalink) Old 04-27-2012, 07:13 PM
Freak4Dell's Avatar
Quoted: 19 Post(s)
Groaned at 6 Times in 5 Posts
So are you connecting this to the OEM navigation display?
Freak4Dell is offline
