Pillar gauge pod - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 197 (permalink) Old 03-28-2007, 03:53 PM Thread Starter
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
Edit:April 2,2008
The pillar pod is in route to me as we as I type.They will be availible in Grey,Tan,and Black.
Here is the interest list
1. djquik1
2. Mazda6smtx
3. xtmesisx
4. WWPearlMS6
5. mtx
6. The Great NY
7. leadbedr
8. rosem32
9. Block8head
10.Big D562
11.Iluv2zmzm
12.Tommyboy44
13. benner410
14. Zoomzoom43
15. 6gt
2010 F-150
1990 F-150
djquik1 is offline
post #2 of 197 (permalink) Old 03-28-2007, 04:05 PM
MrTea's Avatar
Quoted: 38 Post(s)
might want to keep in mind, 90% of the 6's now have an airbag located in the pillars. makes for pod location a bit dangerous.
MrTea is offline
post #3 of 197 (permalink) Old 03-28-2007, 04:32 PM Thread Starter
djquik1's Avatar
Groans: 14
Very true.Mine doesn't have the airbags in the pillar.Thank you for pointing that out.
2010 F-150
1990 F-150
djquik1 is offline
post #4 of 197 (permalink) Old 03-28-2007, 04:37 PM
If they can beat this company's price I might be interested.
http://www.carbontrix.com/mazda.htm
4U2NV is offline
post #5 of 197 (permalink) Old 03-28-2007, 04:40 PM Thread Starter
djquik1's Avatar
Groans: 14
here is the link that i found.It says most projects range from $40-$60.
http://www.gaugepods.com/custom.html
2010 F-150
1990 F-150
djquik1 is offline
post #6 of 197 (permalink) Old 03-28-2007, 04:43 PM
Sounds good to me, let me know. As long as it looks good, that's a great price. I'd be glad to give up my pillar if needed also.
4U2NV is offline
post #7 of 197 (permalink) Old 03-28-2007, 04:47 PM
leadbedr's Avatar
Very true.Mine doesn't have the airbags in the pillar.Thank you for pointing that out.[/b]
How do you know if you have air bags or not?
leadbedr is offline
post #8 of 197 (permalink) Old 03-28-2007, 04:56 PM Thread Starter
djquik1's Avatar
Groans: 14
If you have the window sticker it would say if you had side curtain airbags.If not there should be an SRS tag somewhere in the area of where the pillar meets the headliner.
2010 F-150
1990 F-150
djquik1 is offline
post #9 of 197 (permalink) Old 03-28-2007, 09:08 PM
UCYIMD1's Avatar
Send a message via AIM to UCYIMD1
i'm down
UCYIMD1 is offline
post #10 of 197 (permalink) Old 03-29-2007, 01:00 PM Thread Starter
djquik1's Avatar
Groans: 14
I just got off the phone with the guy from lotek.He said they will not make a pillar pod for that car for liability reasons.They can not be assured that someone would not put it in a car that has side curtain airbags.I didn't argue with the guy,but he said that he wouldn't make it.I have one other company that i can check with that makes alot of BMW stuff and see if they would take that project on.Actually it's the same manufacturer for the plug-n-play hid lamps.I will keep everyone up to date.I do however need a solid count on who would be in.Looks like 3 right now?please correct me if I am wrong.
2010 F-150
1990 F-150
djquik1 is offline
