DIY: How I fixed our 3rd gen road noise issue - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #1 of 56 (permalink) Old 11-21-2013, 09:03 PM Thread Starter
2014mazda6's Avatar
Quoted: 87 Post(s)
So I have seen a lot of grumblings about how bad road noise is in our cars. I have installed some dynamite equivalent in my car and it is now much quieter than my bmw. 128i. I was genuinely surprised by the improvement. All you will need is 50' of 50mm fatmat, a box knife, a small roller to press it into place a heat gun and some aluminum tape to cover any edges that you feel might need it. Takes about 2 hours and remember it does not need to be perfect because it will be covered by a door panel. All said you can get what you need for about $150. Sorry about the quality of some photos.
The instructions are for the front door but the process is the same for the others except for the small piece of trim by the mirror.
Remove the trim by the front mirror
Remove screws that are under the door handles. There are 2 on each door
Pull door panel till it pops off then unplug the switches and remove door pull from panel.
Cut layers of fatmat to size using a box knife (scissors will get clogged up) to cover entire panel heating the fatmat till it is warm enough to adhere then press it into place using the small roller. If you overlap don't worry, just make sure not to cover any holes the panel snaps into. Cover any edges with aluminum tape.
then cover any edges with your aluminum tape.
As you can see it doesn't have to be a work of art. works the same no matter what
It's easier than it looks and made a night and day difference in my car.
Follow steps in reverse when your done and repeat for each panel.
Manual
Blue mica w/White Leather
Injen Intake
20' avarus AV6 wheels
H&R springs
Remote Start
Pioneer dvd-1500
8 speaker infinity sound system
12" infinity sub
2x 4 ch 720w amps
1050w Mono Amp
2014mazda6 is offline
The Following 22 Users Say Thank You to 2014mazda6 For This Useful Post:
aneville11 (08-06-2016), badself (11-22-2013), ballsy (07-26-2014), bja72774 (06-13-2014), cpnfantstk (11-22-2013), danstheman7 (11-21-2013), dellbx (07-26-2014), Donkey Grundle (01-20-2015), Gerrit Oertel (07-19-2016), IHeartGroceries (11-25-2013), jaren253 (02-10-2015), jollyjerry (05-15-2014), lilzeus (06-17-2015), mrdouble99 (11-22-2013), nobouncecap (08-15-2014), OCTOGONPC (01-25-2015), Passenger57 (11-22-2013), Rainmens (11-22-2013), scorerror (11-23-2013), TumbleWeed (12-21-2014), venomxjr (11-21-2013), whitz (04-10-2018)
post #2 of 56 (permalink) Old 11-21-2013, 11:07 PM
Quoted: 15 Post(s)
Looks very nice. Thanks for the walkthru! I might do this in the spring.
venomxjr is offline
post #3 of 56 (permalink) Old 11-22-2013, 12:12 AM Thread Starter
2014mazda6's Avatar
Quoted: 87 Post(s)
Thanks. I meant to add this in the walk through. I would try and do it before it get to hot. The sound deadener will stick to anything and stay there once it's warm. The colder temperatures definitely made it easier to place exactly where you want it to go.
Manual
Injen Intake
H&R springs
Remote Start
Pioneer dvd-1500
12" infinity sub
2x 4 ch 720w amps
1050w Mono Amp
post #4 of 56 (permalink) Old 11-22-2013, 12:37 AM
cpnfantstk's Avatar
Quoted: 225 Post(s)
You did the 4 doors for 150.00 ? What kind of weight do you think it added to the vehicle ? Thanks..
2014 Mazda 6 Touring Liquid Silver Auto
cpnfantstk is offline
post #5 of 56 (permalink) Old 11-22-2013, 02:02 AM Thread Starter
2014mazda6's Avatar
Quoted: 87 Post(s)
it might make more sense to get 100sqft and all the tooling on amazon for a few dollars more and do the trunk as well which is what I did. All said it was less than 30 lbs and if you just do the doors it would be less weight than that.
Manual
Injen Intake
H&R springs
Remote Start
Pioneer dvd-1500
12" infinity sub
2x 4 ch 720w amps
1050w Mono Amp
post #6 of 56 (permalink) Old 11-22-2013, 12:04 PM
hai
Quoted: 53 Post(s)
Groans: 5
Groaned at 4 Times in 4 Posts
This is something I want to do as well with Damplifier or Raammat and also add a layer of thermozite or overkill.
hai is offline
post #7 of 56 (permalink) Old 11-22-2013, 01:48 PM Thread Starter
2014mazda6's Avatar
Quoted: 87 Post(s)
Dont wait. Probably one of the single best improvements to the car.
post #8 of 56 (permalink) Old 11-22-2013, 04:57 PM
Quoted: 139 Post(s)
2014mazda6, thank you so much for sharing. Most folks on the wind noise thread suspect the noise is passing through the window seals and the pillars. looks like that is not true based on what you did. Roughly what percent nosie reduction did you feel after installing the fatmat?
S100Y is offline
post #9 of 56 (permalink) Old 11-22-2013, 05:33 PM Thread Starter
2014mazda6's Avatar
Quoted: 87 Post(s)
It probably was about 30%. Which is huge. I still hear some noise through the windows if a truck or car is right next to the driver window, a given since glass is acoustically transparent. Overall noise was greatly reduced. I mostly hear just the engine now which isn't a bad thing. I am trying some different materials in the actual window seals to see if I can further improve the noise coming into the car and haven't had any improvement yet but will keep everyone posted. I took some of the door seals off and inspected them and they are quite beefy. I suspect there is little to be gained there. Excited to see if others have similar results to mine or see other solutions.
Manual
Injen Intake
H&R springs
Remote Start
Pioneer dvd-1500
12" infinity sub
2x 4 ch 720w amps
1050w Mono Amp
post #10 of 56 (permalink) Old 11-22-2013, 07:21 PM
Quoted: 20 Post(s)
Instead of fatmat, use either Dynamat or Raammat or Damplifier Pro from SecondSkin (the best of all three). SecondSkin also has Spectrum, a spray that produces a viscoelastic layer for sound deadening (many use this spray over the aluminium tape or on wheel wells when there's prominent road noise).
Paracelsus is offline
