DIY: Debadging your car: 3rd Gen - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 43 (permalink) Old 03-11-2013, 10:44 AM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
So, I am sure this has been threaded before but here's for the 3rd gen
The following items can be removed with heatgun/hair dryer and either a clean credit card (plastic card) or 3-5lb test fishing wire.
-Rear Mazda Emblem
-Rear Skyactive Badge
-Rear Mazda 6 Badge
Basically, use your heat source to warm up the glue holding on the emblem/badge. Gently wedge your credit card or fishing line behind the piece and wiggle till you can remove the piece. Go slow and heat different areas to loosen the glue.
The rear Mazda Logo also has two prongs that insert into the body of the car.
The front grille emblem is clipped in at about 6 places if I recall correctly. To remove, gently pry at areas surrounding the emblem with a clean flathead screwdriver. Try not to dig or use too much force. The piece will clip off and then snap back on once you are done. Since there are holes around the whole circle of the emblem, I refrained from making the "evil M" in the front and just did the rear.
Removing the chrome and black lip on the trunk . . . I did not like the crome accent lip on the trunk since I feel its too close to the Hyundai Sonata look. To remove it, there are three caps on the underside of the ledge. They are very noticble and just use a flathead to pop em off and use a socket wrench to do the bolt inside. Once those are off, it will take some wiggling to get the chromed ends out. They are clipped at two points, one near the end and one in the middle. I haven't found the surefire method to easily remove them so I just wiggled it till it came loose and bingo, it came off. Also, you might have to remove your license plate frame if it is bulky and prevents the downward/outward movement.
I did em all classic black and relocated some of them on the car. I let the paint air dry for at least 24hrs before reapplying them to the vehicle. I waiting about a week before I had the chance to reapply the non-chrome trunk lip.
Cleanup!!! Once you have removed your badges from the car, clean up as much of the tacky goo they use by using your fingers and heat. I personally like goo gone to finish up the job and get all the remaining bits off. Use what you think works best.
For reapplying, I used 3M 5lb weight test double stick tape. I am not 100% happy with it but it holds it nice and doesn't look too bad. The issue I have is it is thick and bumps the emblems out a bit. Not a huge deal breaker. Also, its weak enough to just undo easily and reapply somewhere else or with something else. Other suggestions for adhesion are welcomed.
WARNING: if you try to reapply your pieces with glue (elmers,crazy,apoxy) there is a high chance it will seep out before it can set and you might ruin your paint job and emblems.
Good Luck and post if you have questions. Also, show some pics once you get your project done.
I will be posting pics later today. The car is a bit dirty but you will get the idea. Shine and show hopefully this weekend. . .
Edit: pics.
turbomx5 likes this.
2014 Mazda 6 Touring with Tech
Injen CAI & Racing Beats Exhaust
Verde 18' Black sport Rims on Kumho Ecsta 4x with Red Aluminum Lugs and H&R Springs
Thule Aeroblade Roof rack and Bike holder. Tints: Doors 35% Rear 25%
35W 6000k HID's + 35w 6000k HID Highbeams
Hella Horns with Custom Mesh Grille
TheBlur is offline
The Following 5 Users Say Thank You to TheBlur For This Useful Post:
Blackzilla (07-18-2013), ferluno01 (08-04-2014), MM6 (04-01-2013), venomxjr (03-26-2013), Wessel (06-13-2013)
post #2 of 43 (permalink) Old 03-11-2013, 02:24 PM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
Re: Debadging your car: 3rd Gen
Pics. Comments welcome
ID:	86820   Click image for larger version
ID:	86821   Click image for larger version
TheBlur is offline
brown_wallet (03-23-2015), bziko98 (03-11-2013), jcollins28 (03-20-2013), ThaPoet (11-03-2013), Wessel (06-13-2013)
post #3 of 43 (permalink) Old 03-11-2013, 03:27 PM
2ndName's Avatar
Quoted: 84 Post(s)
That looks real good. Definitely something that I'll be doing soon.
2ndName is offline
post #4 of 43 (permalink) Old 03-11-2013, 03:49 PM
Knupsel's Avatar
Quoted: 751 Post(s)
Groaned at 8 Times in 8 Posts
Looks really clean!
Great job!
Sent from AutoGuide.com App
Knupsel is offline
post #5 of 43 (permalink) Old 03-11-2013, 03:52 PM
Quoted: 75 Post(s)
rear lip in black looks good.
2016 Mazda 6 Touring MeteorGray 6-speedMT
2004 Mazda 6s LapisBlue 5-speedMT - sold
bziko98 is offline
post #6 of 43 (permalink) Old 03-13-2013, 08:56 PM
SplitVizionz's Avatar
slick man although my tastes at this point in my life are a little different. I kind of dig the chrome accents for more of a luxury look but what you have done definitely makes it looks sporty and aggressive.
SplitVizionz is offline
post #7 of 43 (permalink) Old 03-20-2013, 11:22 AM
bserra19's Avatar
Quoted: 4 Post(s)
Looks Good Hopefully, That tape holds up
2010 mazda6I 2.5 35%Tint / 35W-6K HID / Yellow LED Fogs / Leather Interior / 18In FF7 245/45/18 Rubber / 5.25 Eclipse components , 6.5 Focal coax/ Alpine 4X45 AMP / kicker CVX ZX400/kicker 12cvx/Front Strut Tower Brace / Eibach Pro Kit
bserra19 is offline
post #8 of 43 (permalink) Old 03-20-2013, 11:32 AM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
I used 5lb strength 3M outdoor (weatherproof?) Double stick. If I notice that it starts to fail in the summer heat, I can always up to the 12lb strength or look for other adhesives.
TheBlur is offline
The Following User Says Thank You to TheBlur For This Useful Post:
bserra19 (03-20-2013)
post #9 of 43 (permalink) Old 03-22-2013, 12:08 AM
5H4D0W's Avatar
Quoted: 117 Post(s)
I was actually going to do this... But i'm going to leave the chrome and get some wheels with machined lip so it matches... But i gotta get that evil M emblem and get the interior lights done... How hard was it to do the lights
5H4D0W is offline
post #10 of 43 (permalink) Old 03-22-2013, 08:48 AM Thread Starter
TheBlur's Avatar
Quoted: 117 Post(s)
Interior lights as in the map/dome lights and door panel lights? If you have a flat head screwdriver and five minutes, its really a no brainer. Pop and play
TheBlur is offline
The Following 2 Users Say Thank You to TheBlur For This Useful Post:
5H4D0W (03-22-2013), ALEORONDON (07-13-2015)
