eBay mudguards - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 04-19-2016, 11:10 AM Thread Starter
eBay mudguards
Has anyone ever tried the mudguards available on eBay? Here are a couple of examples:
SET OF 4 Black Mudguard Splash Guards MUD Flaps FOR Mazda 6 2009 2011 | eBay
FOR Mazda 6 Atenza 2009 2012 MUD Splash Flaps Guard Fenders Mudguards 4pcs SET | eBay
Just thinking about adding these if they work with stock mounting points and the like. Thanks.
Last edited by Rollin Hand; 04-19-2016 at 11:12 AM. Reason: Spacing was Effed Up Malt Liquor.
Rollin Hand is offline
post #2 of 6 (permalink) Old 04-19-2016, 06:07 PM
Dmakayev's Avatar
I bought the Mazda guards for my 2011 and they look pretty identical. The holes should line up, if not, then you're only out $18. I would give it a shot. If it doesn't work, I highly recommend you get the Mazda ones.
Edit: also probably worth finding out if it comes with mounting pins. Mine came with the plastic push pins but they were longer than the regular ones to accommodate for the extra thickness.
Dmakayev is offline
post #3 of 6 (permalink) Old 04-21-2016, 09:59 AM Thread Starter
It looks like they have screws and not push pins, but that can be easily fixed if needed.
post #4 of 6 (permalink) Old 04-22-2016, 05:07 PM
pontiacstogo's Avatar
I purchased the eBay versions for my 2016 Touring. From memory they didn't come with enough e-clips and screws, but a quick trip to Home Depot took care of that. They are identical in size and shape to the Mazda offerings.
I downloaded the PDF of the Mazda instructions and followed them when it came to putting them on.
I fitted all four without having to remove the wheels/tires. A stubby Phillips screwdriver is needed for the rears if you go that route. The fronts took all of 10 minutes to do. The rears were a PITA. You have to pull the bumper sides out from the fender to see where you need to cut the inner liner. Still pretty straightforward. My biggest regret? That I didn't put them on the car BEFORE I subjected it to a PA winter. I think they would have saved a lot of chips and rash.
pontiacstogo is offline
post #5 of 6 (permalink) Old 05-02-2016, 06:20 AM
I would spend a little more and consider Mazda guards for proper fit and great quality.
brydenco is offline
post #6 of 6 (permalink) Old 05-06-2016, 09:11 PM
michaelsteinbach's Avatar
Quoted: 44 Post(s)
The ones in the first link look identical to the Mazda parts. The second link do not.
michaelsteinbach is offline
