?? how to remove mirror's covers ?? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 19 (permalink) Old 07-30-2011, 03:09 PM Thread Starter
dardano's Avatar
Send a message via MSN to dardano
Question ?? how to remove mirror's covers ??
HI,
Is there here any workaround to remove the painted mirror cover part ? I need to repaint them
Is it just "clip-on" or I need to remove the whole mirror and unscrew some parts ?
Thanks
Fred
| 2010 Mazda 6 2.5L GT w/ Luxury package | Black Onyx |
dardano is offline
post #2 of 19 (permalink) Old 07-30-2011, 04:01 PM
Quoted: 11 Post(s)
Groans: 5
Groaned at 6 Times in 4 Posts
Follow the door panel removal thread as it is a great guide! There are 3 screws in the door that need to be removed: one by the latch, one by the light at the bottom of the door and one in the door pocket thing. You can't see the screw in the door pocket because it is being covered by a crappy felt/plastic cover. You basically have to rip up the cover to get to the screw which is located in the middle of the pocket. When I pulled up that cover in the pocket it tore in half so be prepared for that. Naughty Mazda for putting a stupid cover in there and a screw underneath. Shame Shame.
Once you get the screws off, go around the outer edges of the door with a big handled flathead screwdriver and pop each one of the plastic tabs away from the door itself. There are 2-3 on each side. Once you get that off you can take off the panel and get to the mirror.
The nuts are easy to remove from the mirror. The trouble I had was with the connector plug. Removing that seemed to take the jaws of life and for me to channel my inner strength to get it off. Once you get it off, removal of the mirror is complete.
http://forum.mazda6club.com/interior...or-panels.html (door panel removal is in there)
07 6i tungsten grey metallic: clear side markers (purple LEDs), magnaflow catback, full Polk audio sound system, OZ superleggeras (gunmetal), 6000k HID's, badgeless grill, stickerbombed wink mirror, rain guards, red calipers
something funny
oregonducks is offline
post #3 of 19 (permalink) Old 07-30-2011, 04:34 PM Thread Starter
dardano's Avatar
Thank you for your answer.
Maybe I'll paint them aluminium to have a "audi S serie" look.
I'll think about that
dardano is offline
post #4 of 19 (permalink) Old 07-30-2011, 04:44 PM Thread Starter
dardano's Avatar
My car is 2nd gen, don't know if 1st gen guide will work on my 2nd gen Mazda6.
Lets see how it work.
dardano is offline
post #5 of 19 (permalink) Old 07-30-2011, 05:39 PM
Quoted: 11 Post(s)
Groans: 5
idk how to remove anything on the 2nd gen sorry.
something funny
post #6 of 19 (permalink) Old 07-30-2011, 07:07 PM
michaelsteinbach's Avatar
Quoted: 44 Post(s)
Yes, please always check what section you are in before giving disassembly information to someone with a different car than you.
You don't need to remove the inside door panel on the 2nd Gen at all to remove the mirror cover.
OUTER MIRROR GLASS REMOVAL
1. Press area B of the mirror glass so that area A moves outward.
2. Detach pin A while lifting up the inside of the mirror glass holder.
3. Pull the mirror glass holder and remove pins B.
4. Disconnect the connectors. (vehicles with heated outer mirrors)
5. Remove the mirror glass holder and the outer mirror glass as a single unit.
OUTER MIRROR GARNISH REMOVAL/INSTALLATION
1. Remove the outer mirror glass from the outer mirror. (See 09-12-31 OUTER MIRROR GLASS REMOVAL.)
2. Grasp the upper side of the outer mirror garnish and remove it by pulling it in the direction of the arrow.
3. Install in the reverse order of removal.
Hope this helps.
~Mike
Name:	Mirror Glass.jpg
ID:	79780   Click image for larger version
Name:	Mirror Garnish.jpg
michaelsteinbach is offline
post #7 of 19 (permalink) Old 07-30-2011, 09:42 PM Thread Starter
dardano's Avatar
Hope this helps.
~Mike
Thanks a lot, that will help me for sure.
dardano is offline
post #8 of 19 (permalink) Old 02-28-2013, 11:54 AM
does the glass have to be remove to remove the back?
Can i just follow the pulling of off the backing?
azreal1983 is offline
post #9 of 19 (permalink) Old 02-28-2013, 01:05 PM
Quoted: 11 Post(s)
glass doesnt need to be removed, just need to pull hard on the back cover.
2009 Mazda 6 - Performance White V6
Ankit69 is offline
post #10 of 19 (permalink) Old 02-28-2013, 01:18 PM
100% CANUCK
Mr.Smoke's Avatar
Quoted: 1305 Post(s)
Groaned at 8 Times in 8 Posts
Just turn the glass all the way to one side and you will be able to see the little tabs on the inside holding the cover on. Then get in there with a flathead screwdirver and get some of the tabs loose. Then just work your way around. Thats how i git mine off.
If you just pull hard on them like this guy ^^^^ said, you are bound to break something.
Mr.Smoke is offline
The Following User Says Thank You to Mr.Smoke For This Useful Post:
cnephew4 (04-22-2016)
