DIY: broken oil pressure sender switch connector - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 12-29-2018, 02:24 PM Thread Starter
Quoted: 4 Post(s)
Replaced my oil pressure sender switch and the a small piece of the connector from the harness broke. It connects but isn't super tight like it should be. Do I need to replace the harness / connector or will it be ok to roll as is?
this car seems to have the most brittle electrical connectors everywhere...
Current: 2004 Mazda 6S 3.0L Wagon | 2015 Mazda CX-5 | previous: 1990 Miata, 1992 Mazda MPV V6
Tim_Y is offline
post #2 of 5 (permalink) Old 12-29-2018, 03:02 PM
Quoted: 35 Post(s)
I'd probably replace it, and considering the car is 15 years old I am not surprised.
Mad Myche is offline
post #3 of 5 (permalink) Old 12-29-2018, 03:25 PM
Quoted: 316 Post(s)
It should be fine if you can keep it attached securely. A plastic pull tie or metal twist tie may be "engineered" to strengthen your connection.
If you are salvage yard visitor you could clip a complete one and re-pin your into it.
On a side note:
I tried to pull my sender out to test oil pressure after my light started flickering at idle (loose connector) and the sender just spins in the block (not good). Being able to just fix a connector is a blessing in my book.
Modifications:
.MSP slotted brakes & rotors
DrFeelGood is offline
post #4 of 5 (permalink) Old 12-30-2018, 05:52 AM
waughoo's Avatar
Quoted: 315 Post(s)
I don't think I ever heard that it was just a lose connection. Good to know you found a solution @DrFeelGood .
Alex
, and
waughoo is offline
The Following User Says Thank You to waughoo For This Useful Post:
DrFeelGood (12-30-2018)
post #5 of 5 (permalink) Old 12-30-2018, 02:40 PM
Quoted: 316 Post(s)
I can't say for sure if it was the connection or grounding (as a result of stripped threads and buildup) but it is working (until it isn't). I am never pulling that thing out (unless it starts gushing oil). If the sender ever fails I will put an oil filter sandwich adapter plate in and connect a sender to that.
Modifications:
