DIY: Manual Gearbox Fluid Change - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 29 (permalink) Old 05-06-2018, 04:54 PM Thread Starter
Mitchapalooza85's Avatar
Quoted: 49 Post(s)
This will be a basic DIY on performing a Manual transmission fluid change on 2014+ models. I take zero responsibility if you screw it up, cut corners, use incorrect fluid etc so follow at own risk.
Tools Required:
1: Jack with jack stands OR Car Ramps
2: Wheel Blocks
3: 10mm socket & ratchet, Optional(Small Power Impact gun to speed up the process)
4: Phillips screw driver or Phillips bit with Impact gun
5: Flat head screw driver, Optional(Plastic fastener removal tool to help remove plastic tabs from undercarriage)
6: 23MM Socket Standard length (Deep socket will have issues removing Fill plug due to cross member clearance)
7: Optional but much easier: 18" Breaker Bar used with 23MM socket
8: Torque Wrench
9: 2 Gaskets for Fill & Drain Plugs Same Part No. 9956-41-800
10: 3 Quarts of Gear Box Fluid (I used Redline SAE 75w80 GL-4)
11: Manual Pump with hose 24" minimum or 24" hose with Funnel
12: Shop rags
13: Drain pan
14: Optional Cold beer
Step 1: Make sure car E-Brake is engaged if using Jack.
Step 2: Jack up car (Everyone has their own particular spot they use), apply jack stands in desired location/Drive car onto car Ramps(2nd set of eyes to guide car up ramps would be recommended, engage E-brake).
Step 3:Using Flat head screwdriver & Plastic fastener removal tool remove all plastic tabs from undercarriage.
Step 4: Using 10mm Socket & ratchet/Power Impact gun & slowly remove all 10mm screws
Step 5: Remove undercarriage & place to the side.
Step 6: Place Drain Pan underneath the Drain Plug
Step 7: Using 23mm socket with breaker bar break loosen the Fill Plug first, ALWAYS verify it can be removed prior to draining transmission.
Step 8: Now using same socket & breaker bar break loose the drain plug & remove, drain transmission.
Step 9: While transmission is draining remove the old gasket off of drain plug & replace with new gasket. (NEVER REUSE GASKET BEING THEY ARE A ONE TIME USE GASKET, REUSING WILL CAUSE SLOW LEAK & WILL REQUIRE TO REDO THIS JOB.)
Step 10: Remove Fill plug & replace Gasket as well.
Step 11: Reinstall Drain plug with new Gasket, Torque down 30-43 ft/lbs
Step 12: Open Hood
Step 13: If using Hose with funnel run hose from top of motor down to the Fill location & insert hose 2-3 inches inside so that hose won't slide out during filling process, If using pump you can pump fluid underneath car.
Step 14: Now slide the same drain pan underneath the fill location to catch the runoff of transmissions fluid when adding.
Step 15: Add fluid to transmission (you will use 2 at minimum, I had to use 1/4 of 3rd bottle being front end of car was jacked up)
Step 16: Continue adding fluid until you see the fluid running out of the fill plug.(You are now Topped off)
Step 17: Remove hose from fill location
Step 18: Reinstall Fill Plug & Torque down 30-43 ft/lbs.
Step 19: Remove Drain Pan
Step 20: Reinstall undercarriage
Step 21: Use car Jack & Jack car up to remove Jack stands then lower car back to ground/If on car ramps remove blocks from rear tires, disengage E-Brake & drive car off ramps.
Job Completed!
ID:	220066   Click image for larger version
ID:	220074   Click image for larger version
ID:	220082   Click image for larger version
ID:	220090   Click image for larger version
Name:	MTX Fill-Drain Plug Layout.JPG
BrianU likes this.
Mitchapalooza85 is offline
The Following 2 Users Say Thank You to Mitchapalooza85 For This Useful Post:
Byakuya (05-07-2018), dasrider (05-08-2018)
post #2 of 29 (permalink) Old 05-07-2018, 01:51 AM
TitaniumVT's Avatar
Quoted: 425 Post(s)
Groans: 5
Groaned at 8 Times in 6 Posts
Great write-up and photos, Mitch. Thanks for taking the time to do this for the benefit of the rest of us.
TitaniumVT is offline
post #3 of 29 (permalink) Old 05-07-2018, 08:37 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2907 Post(s)
Originally Posted by TitaniumVT View Post
Great write-up and Mitch. Thanks for taking the time to do this for the benefit of the rest of us.
What he said. Adding to my 1 stop shop
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is online now
post #4 of 29 (permalink) Old 05-07-2018, 10:58 PM
GerryB's Avatar
Quoted: 346 Post(s)
Yes, indeed. Many thanks.
GerryB is online now
post #5 of 29 (permalink) Old 05-08-2018, 10:22 AM
dasrider's Avatar
Quoted: 138 Post(s)
Great writeup with pics!
However, I would highly recommend you remove the fill the plug first. Think about it, if you remove (or even break loose as you've described) the drain plug, but can't remove the fill plug, how will you replace any fluid that drains out?
This probably won't be an issue with cars as young as ours, but a seized up fill plug could be a real issue on an older vehicle. I had this exact problem with a 1994 Ford Ranger 5-speed with 411,000 miles with a rebuilt transmission.
dasrider is offline
post #6 of 29 (permalink) Old 05-08-2018, 10:31 AM Thread Starter
Quoted: 49 Post(s)
True
My definition of breaking loose is once you loosen the Fill plug with the breaker bar you should be about to unscrew by hand at this point. If you can freely spin the screw after using the Breaker bar there shouldn't be any reason that the Fill plug won't come out.
post #7 of 29 (permalink) Old 05-08-2018, 11:41 AM
dasrider's Avatar
Quoted: 138 Post(s)
Originally Posted by Mitchapalooza85 View Post
True
I just reread your directions, is step 7 supposed to be break the "fill" plug first?
dasrider is offline
post #8 of 29 (permalink) Old 05-08-2018, 05:08 PM Thread Starter
Quoted: 49 Post(s)
Yes sir break loose the "Fill" plug first
post #9 of 29 (permalink) Old 05-09-2018, 11:43 AM
waughoo's Avatar
Quoted: 422 Post(s)
Step 7: Using 23mm socket with breaker bar break loose the Drain Plug first always, don't remove just verify it can be removed prior to draining transmission.
@Mitchapalooza85 it looks like it still reads drain plug first... you might want to make a quick edit as I think your intention was to have it be fill plug first (or at least crack it off to verify)
Alex
, and
waughoo is offline
post #10 of 29 (permalink) Old 05-09-2018, 12:07 PM Thread Starter
Quoted: 49 Post(s)
EDIT has been made, Good eye sir!
