DIY: 2016+ rear brakes - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 14 (permalink) Old 06-21-2017, 12:33 AM Thread Starter
Quoted: 22 Post(s)
Hi folks, the front brake DIY is extremely straightforward and well-covered by previous members, but the rears on a 2016+ are a bit different. Just wanted to show you some quick pics and explain the basic process of dealing with this new design.
First thing's first, I had to order factory OEM brake pads from an online Mazda parts company. I could not find the correct part number when searching, and had to research the forum here for a part number. The hard part came when some folks describing the part number used "o" in place of "0", and so on. But I eventually nailed it down, here it is:
GMY0-26-43ZB
The factory original pads are made by TRW, and the replacement OEM pads continue this. Other members have researched this and know them to be OEM's for German brands that use electronic parking brakes.
You can see the plastic electronic parking brake device in this pic.
So first jack one side and set a jackstand under the rail. Then made sure the parking brake is OFF, and remove the wheel. Pop the hood and then undo the brake cap to take pressure of the system!
Use a T30 Torx to remove the plastic parking brake device, there's just two screws that holds this. Clearance is tight, I used a T30 bit on a ratchet first, but had to swap to an L Torx to clear the shock.
Unbolt the caliper, hammer off the stock rotor (with a rubber mallet), and if needed, clean off the rust scale on the mating surfaces with a metal brush and brake cleaner, and install your rotor. I went with a new Stoptech slotted rotor.
Pull the pads, you'll need to clean the glue off the piston and brake pad bracket. I used brake cleaner and a nylon bristle brush to get in there, worked well and its safe.
Now this part is very important! Take a T40 Torx and insert it in the back end of the brake caliper actuator. Turn it clockwise until it stops, which for me only took a few turns.
This resets the emergency brake part behind the regular brake piston. Then use a tool (or what I did, I used a woodworking clamp...don't judge...it worked) to carefully press back the piston. Go slow, and clean the piston's rubber seal as you go. I love using Tub-O-Towels solution-soaked towels in these situations.
Install the new brake pads and hardware, don't add grease to the backside of the pads, you'll prevent these suckers from sticking like they need to. Bolt up the caliper, screw on the e-brake motor, check your torque on all the bolts, get your wheel back on, and drop that side back down. If this is the last wheel you're doing, screw the brake cap back on and drop the hood.
Do the other side, and then when you're all done with both, re-engage the parking brake and listen to the motors whirl for a while until they cinch down. Then disengage and re-engage a few times, just to make a sure.
For me, this is all it took. I of course did my fronts first so right after this, I took the car out and tested my new brakes. EXTREMELY impressive difference from what I started with on my used ~24k mile new-to-me 2016.
2016 Mazda 6 Touring
Lanson is offline
The Following User Says Thank You to Lanson For This Useful Post:
Byakuya (06-21-2017)
post #2 of 14 (permalink) Old 06-21-2017, 07:47 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2882 Post(s)
Good write-up. I forgot that the 2016+ went with the electronic parking break and therefore are a bit different. The rears on the "older" 2014 and 2015 models are basically identical to the fronts - did mine about a month ago
Adding this to the DIY section of my 1 stop shop.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #3 of 14 (permalink) Old 06-21-2017, 10:23 AM Thread Starter
Quoted: 22 Post(s)
Exactly, the rest is cake, no issues at all. I just wish we had an option for a bigger brake without going "big brake kit, due to wheel size.
Lanson is offline
post #4 of 14 (permalink) Old 07-05-2017, 02:05 PM
Quoted: 139 Post(s)
Byakuya, the C-Clamp is good to push the rear caliper piston for 2014? No need to twist with needle nose pliers?
Did you go with OEM brake pads or something different? My rear pads are at 20% and soon need a replacement, surprisingly fronts are at 50%.
S100Y is offline
post #5 of 14 (permalink) Old 07-05-2017, 02:13 PM Thread Starter
Quoted: 22 Post(s)
Originally Posted by S100Y View Post
So the C-Clamp is good to push the rear caliper piston for 2014? No need to twist with needle nose pliers?
You are speaking about the 2014. I don't know about that, this DIY help tutorial is for 2016+.
Lanson is offline
post #6 of 14 (permalink) Old 07-06-2017, 12:15 PM
Shiro Shinobi
Byakuya's Avatar
No the rears are basically impossible to get with a C-Clamp (trust me, I tried). You'll be needing the pliers
Current:
, Sold:
, 3rd Generation
Byakuya is offline
post #7 of 14 (permalink) Old 07-06-2017, 12:33 PM
Quoted: 139 Post(s)
Did you go with Mazda OEM rear brakepads or something different?
S100Y is offline
post #8 of 14 (permalink) Old 07-06-2017, 01:13 PM
Shiro Shinobi
Byakuya's Avatar
I went with these pads: More Information for CENTRIC 10516790
which are found on this page: 2014 MAZDA 6 2.5L L4 Brake Pad | RockAuto
with these rotors: More Information for CENTRIC 12045084
found on this page: 2014 MAZDA 6 2.5L L4 Rotor | RockAuto
Make sure you double check the year selected (mine is a 2014).
Feel free to PM me with any more questions - don't want to clutter up OP's DIY
Current:
, Sold:
, 3rd Generation
Byakuya is offline
post #9 of 14 (permalink) Old 10-30-2017, 06:12 PM
how did you just close it with a "woodworking" clamp ( is that just a c Clamp)?
I had the brake caliper tool and couldn't get that piston back in. The piston had a 3 pronged end and the kit didn't have a piece for that.
Came here to see how you guys handled it.
Istaly is offline
post #10 of 14 (permalink) Old 11-01-2017, 02:50 AM
flyandi's Avatar
Quoted: 260 Post(s)
You need to turn back the electronic brake cylinder first. Don't even attempt to push the piston back before you do that or you will destroy your caliper.
I wrote this a while back: http://forum.mazda6club.com/mazda6-a...adzda-6-a.html
flyandi is offline
