DIY: Notes On MT Lube Change 6 MT - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 08-25-2015, 12:31 PM Thread Starter
tickerguy's Avatar
Quoted: 912 Post(s)
Groaned at 7 Times in 7 Posts
I'm in the low 50k mile range now on my '15 6 MT and decided to change the gear oil -- why not, since it's just the oil and a couple of washers.
Observations: Almost exactly 2 qts drained out. My oil was not in bad shape at all; still had a decent oil-ish color and a bit of black material on the drain plug. I've heard some others say their oil looked awful in the 20-30k mile area; mine did not, it was fine. There was no reason in terms of oil quality to change it, in short -- at least on MY car I'd be comfortable going to 75k at least as an interval and perhaps to 100k.
2 qts, filling with a pump from the bottom, did not completely fill it. I filled on ramps, loosely put the fill plug in, backed off the ramps and removed the plug, expecting a bit to drip out (since capacity is listed as just under 2qts and the ramps are a bit of an incline.) It was not full, but was probably within the "safe" zone as a finger down the hole was able to feel oil. It took about another third of a quart to fill it all the way, and then when pulled back off the ramps and the plug was removed perhaps a half-ounce dripped out. The moral of this story: Buy three quarts of oil, not two, and if you fill on ramps to where it's full you won't have much come out when you pull the plug after backing off them. Also, the washers on the drain and fill plugs are aluminum and distort when the plugs are torqued; as such they are one-time use and if you try to re-use them they'll probably leak. Get some new ones from the dealer before you do this; they're cheap.
I am running MTL mostly because I've liked it before in manual gearboxes. I didn't notice anything materially different in shifting on a quick test drive after finishing up.
One final note (some of you may know this, but I bet many do not): Never run GL-5 gear oil in a MT that is specified for a GL-4 (as this one is.)
This includes oils that have both GL-4 and GL-5 specs on the label; if GL-5 is on the label DO NOT USE IT! And by the way if you look in the auto parts stores you'll find virtually all are either GL-5 or dual-spec.
If you ignore this warning you will destroy the synchronizers and wind up having to tear the gearbox apart to replace them; GL-5 oils have additives in them designed for very high-pressure environments that coat the internal parts, particularly hypoid gears. This is great except that the coating is of higher strength than the brass that the synchros are made of and as a result the synchro material will shear instead of the coating under load and soon you will have no synchros! The moral of the story is that a higher number is not always better and if the GL-5 designation is on the label do not use it in a synchronized gearbox unless the manufacturer specifically says it's ok, even if the other (e.g. GL-4) spec is present on the label as well.
tickerguy is offline
The Following 2 Users Say Thank You to tickerguy For This Useful Post:
Byakuya (08-25-2015), Donkey Grundle (08-25-2015)
post #2 of 8 (permalink) Old 08-25-2015, 02:52 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2882 Post(s)
Lots of great info here ticker - added to my 3rd gen 1 stop shop.
Side note: for the AT, Mazda doesn't recommend a change until 80 - 100k miles; though doing it this early won't hurt a thing.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is online now
post #3 of 8 (permalink) Old 08-25-2015, 04:11 PM
Donkey Grundle's Avatar
Quoted: 439 Post(s)
Groans: 22
So which MTL did you use? I used to put Redline MTL in all of my BMW transmissions and really liked the results.
Donkey Grundle is online now
post #4 of 8 (permalink) Old 08-25-2015, 04:12 PM Thread Starter
tickerguy's Avatar
Quoted: 912 Post(s)
Redline; I've been happy with it in the past although on my VWs I've run their gear oil.
post #5 of 8 (permalink) Old 08-25-2015, 04:24 PM
Quoted: 439 Post(s)
Groans: 22
Great, be sure to let us know any differences you notice from the OE fill.
post #6 of 8 (permalink) Old 08-25-2015, 04:46 PM Thread Starter
tickerguy's Avatar
Quoted: 912 Post(s)
Will do if I note anything different....
post #7 of 8 (permalink) Old 08-25-2015, 05:54 PM
Nihilus's Avatar
Quoted: 155 Post(s)
Groans: 9
I just swapped my gear oil for the MX5 (recommended at 30k, did it at 35k) and did so with Motorcraft XT-M5-QS. It's great stuff, recommended by lots of Miata folks, as well as Speed owners like SonicNutrition. Idk if its good for 3rd gens but its worth a look at it.
Clicky
It's great stuff, really smoothing out my shifts, and in addition to my new Sure stainless knob, it feels like a whole new car.
06 MX5 GT - w/ Susp. Package (Bilstein shocks and LSD), Prog. Tech. Springs, Bose/xCarlink/10 Inch Fosgate P2 with Alpine 250w amp, RoadsterSport 2 Muffler, Racing Beat catless midpipe, AEM CAI, RHT
05 6i, Glacier Silver - Traded!
Nihilus is offline
post #8 of 8 (permalink) Old 12-28-2015, 10:05 AM
solar365's Avatar
Quoted: 741 Post(s)
Groaned at 6 Times in 6 Posts
I'll add that you need a 23MM socket to remove the two bolts.
Also you can gravity fill from the top with the hood open if you remove the factory intake box. Just get clear plastic tubing from home depot and tape it to an oil funnel. This will allow you to fill the oil with the car off the jack stands.
Flowmaster dBX Exhaust---Corksport SRI W/Cold Air Box---OrangeVirus Tuned ECU---90lb Weight Red.---Shifter Mods
solar365 is offline
