DIY: EGR Modification/Optimization (3.0L V6) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #1 of 136 (permalink) Old 01-20-2008, 09:57 AM Thread Starter
The Great NY's Avatar
Quoted: 37 Post(s)
Groans: 7
Groaned at 37 Times in 32 Posts
Ok.........i was asked make a how to on how to do this mod. But first here is a quick explaination of what this mod if for and what it does.
REASON FOR DOING THE EGR MOD:
the Mazda 6s from the factory has a few flaws that may be small and some that can even lead to detrimental damage to the car itself. some of these flaws and/or shortcomings can usually but not always be fixed. But of course the manufactureer wont do it.
Anyway, the design of the Mazda 6s EGR system puts the tube of the EGR directly in the middle of the intake tract. Thats bad business. Basically it blocks the airflow to the cylinders. This compounded with a decently bad design of an Intake Manifold causes 2 issues.
1. one of the 2 cylinder banks will run significantly leaner than the other. How significant are we talking here?
--it has been documented that there is about a 5%-7% difference in fuel trims between the front and rear banks.
******now on a stock motor it probably wont hurt it in the long run. but most of us owners tend to enjoy modding our rides and getting more power. and if this is left stock it could cause engine failure when dealing with power adders such as turbos, superchargers, and nitrous. again 5-7% may not sound like a lot. but that could be the difference of you keeping your 12.2 AFR in one bank......and leaning out to 13.0AFR+ in the other. then boom******
2. it blocks some airflow all together. restricted airflow=power lost
*****drive about 50mph.......stick your hand out the window. feel the pressure on your hand. you get my point*****
HOW-TO:
**TOOLS NEEDED**
-8mm & 10mm sockets with accompanied rachet.
-corresponding 6" or more extension
-8mm rachet wrench(i'll explain why later)
-5/16" socket (i have an Injen CAI with hose clamps, size may vary, per intake)
-newpaper/paper towel/towel (either of the 3 will suffice)
-a hacksaw/dremel with cutting bit/ air powered wiz wheel(either of the 3 will suffice granted you have an air compressor the 3rd would be the fastest)
-pliers(needle nosed/snub nosed)
-flat tip screwdriver
****sounds like a lot but its really not****
TERMS:
EGR- exhaust gas recirculation
IM- intake manifold
TB- throttle body
AI- air intake
PROCEDURE:
1. disconnect the neg. side of the battery 10mm (ensure that its away from the terminal and wont accidentally touch it)
2. look on the TB.........on the side closest to the firewall there is a plug with a lil red clip on it. Pull it up with your fingernail. and remove that plug from the TB.
3. disconnect the AI from the TB using the clamp closest to the TB. NOTE-actual nut size on clamp may vary from intake to intake.
****if you have a CAI there may be another Nut to loosen down by where the air filter goes into the fender(its a damper/mounting nut****
4. remove the engine cover (3 nuts)
5. remove the 3 EGR valve mounting bolts
***the bolt furthest to the right can be a PITA if using a ratchet. it can be done but i suggest using a 8mm rachet wrench***
6. remove 3 vacumm hoses from rear of IM.
***this is where the pliers and flat tip screwdriver come in handy, use them. do not try and just yank them off, where as you could snap off the nipple on the IM. the one furthest to the right can just be pulled off***
7. remove the 2 connector plugs on the front of the IM
***the other is about 6" directly to the right of this one***
8. remove 8 IM mounting bolts
***NOTE- these bolts will not come out of the IM fully. they are locked inside of it for the most part. do not attempt to remove them***
9. remove IM from engine and EGR valve. once you start picking up the IM off the motor STOP! there is one More hose under the TB you must take off. Just look under the TB and you'll see it. there are also 2 coolant lines on the TB that need to be removed. if you havent done the TB coolant Bypass, now would be a good time to do it.
***once IM is removed, besure to place the IM upside down once removed to keep dirt from getting on the seals. and place a towel or cover material of choice over it to keep debris from getting in the runners. also be sure to cover the ports on the motor as well***
***NOTE- the IM does not have to fully come out of the engine bay to do this. but it make it easier to mask the lower runners on the engine as well as keep the debris you're cutting from getting in there. remember you're are cutting metal, you wont see where all the bits and peices go. but rest assured you dont want it in you're motor....thats for sure!***
10. look at your EGR valve that is now exposed. take note that there is a point to where the tube increases in size. that point is the point you must worry about. if you cut too close to that point the EGR valve will then become 2 pieces. NOT GOOD. you must cut about a thickness of 3-4 quarters before the ridge of the high point
here's a hand drawn version of what you have to do:
***once cut you have now performed the EGR Mod.
11. Put everything back together in the reverse order you took it apart. VOILA! modified/optimized EGR valve.
TORQUE SPECS:
INTAKE MANIFOLD TIGHTENING SEQUENCE:
SECONDARY RUNNERS TIGHTENING SEQUENCE(for shits and giggles..doesnt need to be touched during this mod)
ADVANTAGES OF THIS MOD:
1. increased airflow to the cylinders.
2. more even air distribution.
3. possibly better Gas mileage.
4. getting a head start on having a safer motor for power adders down the road.
5. a happier motor.
TOTAL TIME:
approx. 30-40mins
****if doing the TB coolant bypass at the same time add another 15-20mins on it, but if you do the TB coolant Bypass, its safer to do on a cool engine****
I HOPE THIS HELPS ANYONE WHOM WAS CLUELESS ABOUT THIS MOD. hopefully it'll get pinned!
bih1123 and Chloe Shea like this.
Fully Built - Spoolin' and Juicin'
Flash Tuning For Your Mazda - Hit Me Up
The Great NY is offline
The Following 7 Users Say Thank You to The Great NY For This Useful Post:
bih1123 (08-13-2016), cyyzgnus (09-08-2014), dechaoz05 (01-29-2014), evil_m6 (08-06-2013), Joverload (02-22-2019), sphinx689 (03-10-2010), trbofreak3 (09-30-2013)
post #2 of 136 (permalink) Old 01-20-2008, 10:04 AM
VirtualMirage's Avatar
Thanks, The Great NY!
I was going to be doing this mod either today or tomorrow before my dyno/tune day next Saturday. I pretty much knew how to get to it but your illustrations showing what size sockets I need to use will save me some time from fumbling around.
Paul
2007 Mazda6s GT 5-Door, Tungsten Grey (Auto, 6-speed) :
1/4 Mile: 15.609s @ 89.69 MPH <-- MIR, 3/1/08. Burnout done for traction, Brake torqued around 1700RPMs, Wheelspin off the line. Low trap time due to Cyl #6 misfire.
0-60 MPH (60.3 actually): 6.45s <-- Timed with MSD DashHawk (TCS off, D Mode, no brake torque, some wheelspin off the line). Repeatable. Time should improve with better launching and better tires.
Dyno/Tune (Conservative timing adjustment) 1/26/08 ---> 182.53 HP / 172.33 TQ at the wheels (SAE format)
VirtualMirage is offline
post #3 of 136 (permalink) Old 01-20-2008, 10:07 AM Thread Starter
Quoted: 37 Post(s)
Groans: 7
no problem. alwayz glad to help
post #4 of 136 (permalink) Old 01-20-2008, 10:08 AM
Raynman's Avatar
Sticky-worthy!
Raynman is offline
post #5 of 136 (permalink) Old 01-20-2008, 12:52 PM
Send a message via AIM to xshellshock
Sticky-worthy! [/b]
+1...and I added it to my bookmark list of how-to&#39;s
<span style="color:#FF0000">
- 2006 Onyx Black 6s -
- JL Audio - Boston Acoustics - CPE - Mazdaspeed - Clutchmasters - Fidanza - AWR - Phantom Grip - Enkei - Racing Beat - Fluidampr -
</span>
xshellshock is offline
post #6 of 136 (permalink) Old 01-20-2008, 01:29 PM
benner410's Avatar
Send a message via AIM to benner410 Send a message via MSN to benner410
thanks a bunch for the writeup! I might try this down the road.
The sour taste of being broken down stays long after the sweet taste of cheap is gone.
2003 6s GT - Silver
benner410 is offline
post #7 of 136 (permalink) Old 01-20-2008, 01:33 PM
Boozted's Avatar
Excellent write up. Good time to change the spark plugs too if you wanted.
Boozted is offline
post #8 of 136 (permalink) Old 01-20-2008, 02:24 PM
Send a message via AIM to bumpin_blazer
good write up there. I just might do this today and the TB coolant bypass if I can figure that one out too. anyone have a link to the TB coolant bypass or if there is a how-to on that?
2006 6s Bright Island Blue:
Stock options- bose/moonroof/power seat, homelink mirror
My Goodies added: debadged, 8000K 55w HID Low beams 8000K 55w lower fogs, DDE Raptor Angel Eyes, PIAA Spark 8000K H1(high beams), tail-light mod VG Sharkfin Antenna, Accolade Sport Grill, LED Rear Reflectors and Side Markers, LED rear tail lights RB Rear Sway bar, MS Springs and shocks, and B&M 70264 Transmission Cooler. ADR Cypher 18x7.5s wrapped in General Exclaim UHP&#39;s.
Soon to come- Sniper tuner, headers then finish the exhaust.
bumpin_blazer is offline
post #9 of 136 (permalink) Old 01-20-2008, 02:44 PM
mazda6frek's Avatar
good write up there. I just might do this today and the TB coolant bypass if I can figure that one out too. anyone have a link to the TB coolant bypass or if there is a how-to on that?[/b]
Here&#39;s the link, but I&#39;m afraid it does&#39;nt have any pics:
http://www.mazda6tech.com/index.php?option...3&Itemid=49
And thanks so much for the great write-up NY! Ima definitely gonna have to do this one sometime. Worth a sticky!!!
Silver 03 6s 3.0L MTX: - Apexcone 55w 6000k - Alpine CDA-105 HU - JL Audio 12w3v3 Subwoofer/Rockford Fosgate P-300 Punch Amp - DXR Gloss Black 18x8 +45 - 235/40/18 Nitto Neo-gen ZR - Mazdaspeed Hatch Springs - Megan Racing H-Brace - SU Rear Interior Frame Brace - Mazdaspeed STS - Fluidampr - Cordova Motorsports Polished/Optimized Throttle Body - AWR Racing Transmission/Engine Mounts - CP-E (ylw/race) Engine Mount - CP-E MAFci - MSDS Headers - Custom 2.5 inch Exhaust
mazda6frek is offline
post #10 of 136 (permalink) Old 01-20-2008, 02:57 PM
dmralph's Avatar
Damn it i just did my plugs and pvc last nite and I was thinking about doing this mod . oh well cars are like legos all ways taking them apart...good write up
  • 03 Steal Gray M6s ATX
  • APEXCONE 5K HID KIT
  • INJEN CAI
  • 2 10" SHALLOW MOUNT PIONEERS CUSTOM FIBERGLASS BOX KENWOOD 1K AMP
  • Preditor foot pedals ( from autozone )
  • FOLDING SIDE MIRRORS
  • VSII CF HOOD
  • HYPER BLACK 18" MOTEGI US7
[/list]
  • <span style="color:#FF0000">
  • [b]FUTURE MODS[/b]
  • INJEN CAT BACK
  • CUSTOM GRILL ( FROM THE CLUB HOME PAGE )
  • LEDS EVERYWHERE
  • LOTEK GAUGE POD AND GAUGES
</span>
dmralph is offline
The Following User Says NO Thank You to dmralph For This Un-useful Post:
Modbug (09-30-2013)
