TSC ABS lights - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 01-14-2019, 09:34 PM Thread Starter
Quoted: 4 Post(s)
TSC ABS lights
I bought this car not running.
Swapped in a Fusion motor now it runs and shifts good.
I have the ABS and TSC lights on.
I do not have access to a scanner that does those things.
Any idea what to check?
Crispin Schnur is offline
post #2 of 6 (permalink) Old 01-14-2019, 09:42 PM
bluedevil6's Avatar
Quoted: 202 Post(s)
Is there any way it could be related to that sensor that was not plugged in? Have you had the battery disconnected since you plugged it in, that should clear any faults in the system.
2007 6 Hatch 3.0 V6 ATX
Places to find me-
bluedevil6 is online now
post #3 of 6 (permalink) Old 01-14-2019, 10:51 PM Thread Starter
Quoted: 4 Post(s)
Well it could be for sure. I will unplug the battery for a while and see if that helps.
post #4 of 6 (permalink) Old 01-17-2019, 09:01 AM Thread Starter
Quoted: 4 Post(s)
Well I unplugged the battery for a while and that did not help.
Anyone have any ideas?
post #5 of 6 (permalink) Old 01-17-2019, 09:10 AM
bluedevil6's Avatar
Quoted: 202 Post(s)
Are all of your wheel sensors plugged in and the wires in good shape? I would also check the abs relay (and possibly fuse I canít remember if thereís a fuse just for the abs) as well as the plugs for the abs pump.
Places to find me-
post #6 of 6 (permalink) Old 01-19-2019, 09:39 PM Thread Starter
Quoted: 4 Post(s)
I bought a scanner that does ABS codes.
Left front wheel speed sensor
Auto parts stare wanted $80 for one, I ordered one from ebay for $13
I will report back once get and install it.
