Quoted: 155 Post(s)
Any concerns as mileage gets higher?
I was hoping for some input from people with higher mileage 6's. Mine is currently approaching 160k while it doesn't seem to have any issues is there anything I should start to worry about? The only thing I haven't done is eliminate the pre cats because I'm afraid of breaking off the rusty studs in the head. And I suspect my A/C compressor might be starting to fail. I have deleted the egr tube. The car is a 2007 3.0 V6 with the 6sp auto Aisin trans.
Things I have already done/do:
Spark plugs/ coils
Flushed ALL of the fluids ATF, PS fluid, Coolant, even the brake fluid
Regular oil changes with full synthetic high mileage oil with Hy-Per lube
water pump
cam seal
front crank seal
serp belt
idler pulley
Thanks for any input.
2007 6 Hatch 3.0 V6 ATX
Places to find me-
