MZR DISI Mazdaspeed Engine - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
  • 1 Post By b1lk1
  • 1 Post By b1lk1
post #1 of 8 (permalink) Old 03-20-2018, 03:01 PM Thread Starter
Do these drop in the regular 6, or is there significant fitment issues that make it impractical?
Mrkstills is offline
post #2 of 8 (permalink) Old 03-20-2018, 03:56 PM
b1lk1's Avatar
Quoted: 293 Post(s)
Groans: 19
You'll need everything, including the dashboard harness/cluster/column/keys/etc... Everything is different.
b1lk1 is offline
post #3 of 8 (permalink) Old 03-21-2018, 12:49 AM
babyluv2's Avatar
Quoted: 21 Post(s)
Look at a low mileage 2.5 from a fusion, focus, etc...
Sent from my LG-M150 using Tapatalk
babyluv2 is offline
post #4 of 8 (permalink) Old 03-21-2018, 07:48 AM Thread Starter
Not much of a bump in HP from that swap.
Would the 3.0 fit in there, or is that another fitment nightmare?
post #5 of 8 (permalink) Old 03-21-2018, 08:25 AM
b1lk1's Avatar
Quoted: 293 Post(s)
Groans: 19
Nightmare.
Anything newer than 1998 by any brand is very difficult to swap engine platforms as OBD II is very specific at times as well as problems with passive anti-theft that pretty much all cars have had since OBD II was introduced.
Go with a 2.5L and turbo it. It would be cheaper than trying to swap in a V6/Speed motor and not require extensive parts swapping.
babyluv2 likes this.
b1lk1 is offline
post #6 of 8 (permalink) Old 03-21-2018, 09:24 AM
babyluv2's Avatar
Quoted: 21 Post(s)
You can be the 1st to put a 3.7 from the second gen into a 2.3 body if you're really looking for a bump in hp...and a challenge.
babyluv2 is offline
post #7 of 8 (permalink) Old 03-21-2018, 09:38 AM Thread Starter
I have a 2010 3.7l, and that would be a wicked combination. Not real practical, but at least you can find them, which is more than I can say about turbos for the 2.3 or 2.5.
It does not seem like there is much you can do to substantially increase HP on these cars, so I suppose my first thought is the best; stick to the suspension and electronics and be satisfied with that.
post #8 of 8 (permalink) Old 03-21-2018, 12:20 PM
b1lk1's Avatar
Quoted: 293 Post(s)
Groans: 19
You have to build your own turbo kit, likely cost $4-5K by the time you get it tuned. You could easily push 300HP+ to the wheels with a 2.3L/2.5L with a turbo.
Swapping the motor is simply not an option. You can easily find a replacement car with the motor you actually want for less than what it would cost to swap to a different motor (or to add a turbo for that matter).
b1lk1 is offline
