NEED HELP!! CEL Diagnostic. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #11 of 13 (permalink) Old 01-26-2017, 10:29 AM Thread Starter
I figured why not record whats going on and show y'all it probably will be a lot more helpful or narrow down the solution.
I took this this morning and i should've probably left the driver door open so you can hear it crank better instead of it sounding so muffled.
amc721 is offline
post #12 of 13 (permalink) Old 01-26-2017, 11:33 AM
jman1200's Avatar
Quoted: 85 Post(s)
I don't know the answer but if the vehicle was in "theft mode" wouldn't the light that shows a key inside a vehicle, stay ON?
jman1200 is offline
post #13 of 13 (permalink) Old 01-26-2017, 11:49 AM Thread Starter
Now is where the depth of all come to play... So when the remote starter was removed the car had a weak crank.. thought it was just the battery dying had it charged and it was a little stronger. I then started following wires and found that near the key barrel some wires coming out of the connector had tape on it. When i removed the tape i found more bad wiring I'm assuming from the remote starter. i snipped it out and tried a butt connector but wasn't successful. At this time my anti theft was blinking rapidly whenever i put the key in to try start the car and it wouldn't crank at all. I purchased a new connector with a decent length wire and snipped and soldered the new connector. The antitheft went back to normal and recognize my key and now i get the successful cranking you've seen in the video. I kid you not its sounds a lot better than when my issues first came around and it wouldn't start.
amc721 is offline
