2004 Mazda 6 2.3 Won't start - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 06-22-2016, 06:24 PM Thread Starter
Prophet6's Avatar
Send a message via AIM to Prophet6
Have not drove the car since last week Friday because I went out of town. Came back home to a lot of thunderstorms and excessive rain and finally got a chance to step outside and decided to clean the car but it would NOT START. It's turning over but not actually starting. Battery is good and starter is good. Any ideas as to what it may be or what else I should check.
Prophet6 is offline
post #2 of 7 (permalink) Old 07-06-2016, 09:26 PM Thread Starter
Prophet6's Avatar
Anything guys? Fuel pump? Starter?
Prophet6 is offline
post #3 of 7 (permalink) Old 07-06-2016, 10:25 PM
karlt10's Avatar
Quoted: 25 Post(s)
With your car still having plug wires, it's always possible the humidity is affecting the transfer of spark if your wires are sketchy. Best thing to to is test for spark. If you don't have a tester, simply pull a plug from a cylinder, use ViceGrips to attach it to a metal (non-aluminum) surface, with the plug wire still attached crank the engine. You should see spark. If spark, you have to start to wonder about fuel. I'd check the fuse and relay for the fuel pump.
Eibach springs / MazdaSpeed bars / Bilstein / Steeda Adj FR links / Racing Beat RR links / GTSpec Rear Susp & Trailing Braces / Steeda shock tower brace
EBC Ultimax rotors & pads / StopTech lines / Motul fluid
MSDS headers / Magnaflow cat / Racing Beat mufflers / Cork Sport urethane hangers / WeaponX coils / AER CAI / Fluidampr pulley
EGR mod / FilterMag / Street Unit engine mount /
B&M trans cooler / Amsoil fluid
Mazda iPod adapter
/ CX7 antenna
Continental Extreme DWS / Bridgestone Blizzak
karlt10 is offline
post #4 of 7 (permalink) Old 07-07-2016, 01:07 PM Thread Starter
Prophet6's Avatar
Thanks karlt10 will give this a shot today. Will
Check fuel pump fuse as soon as I get some help I'll have someone turn the key so I can check for the spark. It cranks strong, just won't start
Prophet6 is offline
post #5 of 7 (permalink) Old 07-07-2016, 05:28 PM Thread Starter
Prophet6's Avatar
No spark and no fuel. May be the security immobilizer ??
Prophet6 is offline
post #6 of 7 (permalink) Old 07-07-2016, 09:20 PM
karlt10's Avatar
Quoted: 25 Post(s)
Absolutely could be the immobilizer. Disconnecting the battery for a bit -both terminals- may be worth a try.
Mazda iPod adapter
/ CX7 antenna
karlt10 is offline
post #7 of 7 (permalink) Old 07-09-2016, 12:52 AM Thread Starter
Prophet6's Avatar
No luck today. I did notice that the CEL flashes about 8 times however. This takes me back to my original assumption of it being the crank sensor
Prophet6 is offline
