Should I do my first car service at 1,500 miles? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 14 (permalink) Old 04-27-2014, 10:57 PM Thread Starter
Quoted: 8 Post(s)
Guys,
I purchased my 6 in mid-Nov., 2013. It's almost 6 months since the purchase. As per the owner's manual, I am supposed to do my first car service in mid-May since the time is about to hit the limit.
However, my car has only 1,500 miles on it, which is far less than 7,500 miles limit. In the manual, it recommends the service every 7,500 miles or 6 months, whichever comes first.
I saw some articles claiming the oil that comes with the car is for *break-in* purposes. I am not sure if 1,500 miles is enough for these purposes?
My concern is, if I do not do my first car service when time hits the "6-month" limit, would it void or affect my warranty?
I emailed Mazda, and the reply seems not quite helpful:
"Regarding your warranty inquiry, your Mazda Warranty Information booklet advises any repairs due to lack of maintenance may be declined warranty coverage. However, there is no way for us to predict whether going beyond 7,500 miles or 6 months will affect the vehicle or your warranty coverage."
Any thoughts?
neosunrise is offline
post #2 of 14 (permalink) Old 04-27-2014, 11:09 PM
Quoted: 97 Post(s)
Get it changed, obviously you don't drive much but the same oil for so long and after (I'm assuming, depending on your location) extreme weather changes needs to go, in my opinion, even with such low mileage.
Caliche is offline
post #3 of 14 (permalink) Old 04-27-2014, 11:30 PM
Shook187's Avatar
Quoted: 223 Post(s)
Groaned at 11 Times in 10 Posts
Just change your oil, Why would you risk your warranty? If it says 6 months or 7500 miles whichever comes first what are you actually questioning here?
Shook187 is offline
post #4 of 14 (permalink) Old 04-28-2014, 12:56 AM
Quoted: 23 Post(s)
I got my first service 4 months in with 1300 miles.
Schedule 2 maint.
Lot's of stop and go city traffic only.
Like the others have said, why risk it?
It costs less than 300 bucks a year for peace of mind.
kosomoto is offline
post #5 of 14 (permalink) Old 04-28-2014, 09:45 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2783 Post(s)
Got my first service at 6000 miles on the dot, but I did that in just under 2 months of ownership soooo...
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #6 of 14 (permalink) Old 04-28-2014, 10:21 AM
jguttes's Avatar
Quoted: 59 Post(s)
Haven't thought about that... I'm on a 1,000 mi/month pace and plan on getting my first oil change at 5,000 (5 months) but after that I'm going to go 7,000 - 7,500 which should be 7 months... guess I should put some thought into going on a 6 month routine.
2014 Mazda 6 Grand Touring - Snowflake White
1996 Mazda B2300 Regular Cab 4x2 SE
jguttes is offline
post #7 of 14 (permalink) Old 04-28-2014, 10:48 AM
ExB5's Avatar
Quoted: 625 Post(s)
Groans: 18
Groaned at 14 Times in 14 Posts
If my car only has 1.5Kim on the clock at month 6...even on the factory break in oil, I'd have it changed. 6 months would be the max for my engine oil. Nothing beyond (and I never did go past, on any of my rides).
Now, if Corprate Mazda emails me that stipulates anything warranty-wise..I'd give it the benefit of the doubt and play it safe (no hassles). I'll bring it to the dealer for the 1st OCI. Just to show adherence and "good faith" to that Corporate warranty email reply (documented), should anything "defective" pops out. On the succeeding OCIs, I would do the oil changes myself if I so decide. Just keep paper trails/documentation/receipts, etc.
ExB5 is offline
post #8 of 14 (permalink) Old 04-28-2014, 02:31 PM
Quoted: 27 Post(s)
The OP's question is a good one. What's everyone's thought on low mileage and a brutal winter? Still change out the oil at the 6 month mark? The Mazda service tech says that they use synthetic oil now which should be able to have a much higher tolerance of driving variables... which leads me to believe that the interval of oil changes can be widened.
dbam987 is offline
post #9 of 14 (permalink) Old 04-28-2014, 02:58 PM
Shook187's Avatar
Quoted: 223 Post(s)
What's in question? 6 months or 7500 Miles whichever comes first. There's absolutely nothing in question.
Shook187 is offline
The Following User Says Thank You to Shook187 For This Useful Post:
VWGTI123 (04-28-2014)
post #10 of 14 (permalink) Old 04-29-2014, 12:38 AM
Quoted: 84 Post(s)
I don't think there was anything special about the oil in the vehicle. Just had ZDDP as the additive (typical for most oils) which helps during break in. The Castrol oil most Mazda dealerships are using now should have the same stuff (I haven't verified by test yet).
Found this from Edmunds...
5. When you buy a new car, change your oil at 3,000 miles to remove metal particles from the engine break-in process. There might be a grain of truth to this, according to the experts at Blackstone. Oil samples from engines during the first 3,000 miles of driving show elevated "wear-in" metal levels, coming from the pistons and camshafts, says Ryan Stark, Blackstone's president. But he added, "To me, it doesn't make that much difference because if the filings are big enough to cause damage, they will be taken out by the oil filter."
However, a Honda spokesman says its cars come from the factory with a special oil formulation for the break-in period. Honda advises owners to not change the oil early. Stark said Blackstone Laboratories' test of Honda's break-in oil shows it contains molybdenum-disulfide, an anti-wear additive. But Stark said Honda is the only manufacturer he knows that's using special break-in oil. The take-away? If there are any special break-in recommendations from the manufacturer, follow them. And consider analyzing the oil at 3,000 miles
All I know is that my Mazda did not have moly disulfide as an additive when I purchased it.
wardorican is offline
