-   Engine / Drivetrain (https://forum.mazda6club.com/169-engine-drivetrain/)
-   -   Grinding noise during acceleration through corners (https://forum.mazda6club.com/engine-drivetrain/290049-grinding-noise-during-acceleration-through-corners.html)
guyforks 01-23-2014 05:11 PM
Hello all,
I recently purchased this vehicle and during the test drive didnt notice anything. A few days later I've been hearing a grinding/clicking noise when I accelerate with my steering wheel turned. It doesn't seem to favor any one side. I was thinking CV boot initially but its more then just a click.
If I'm turning through a light and the noise is present, I can take my foot of the gas and it stops even though the car is still moving. Once I put my foot back on the accelerator the noise re-appears. Keep in mind after I've completed my turn and i'm driving straight again its fine. Of course here in MN its -18 so I cant get under the car to look at much at the moment.
Appreciate any insight into this issue.
Drizzoh 01-23-2014 05:16 PM
I'd check the motor mounts and the axles as well as all of the front suspension control arm bushings. The first gen's are getting up there in age now so they're starting to wear out those suspension pieces. I just replaced all of the above, FWIW, lol.
guyforks 01-23-2014 11:00 PM
Thanks drizzoh. I'll look it over tomorrow. Were getting a warm burst to 30 degrees then back to 2 degrees. What did all that run you for parts?
Snakes 01-26-2014 01:05 PM
Yeah I've got the exact same problem, I can't figure out whats going on, and let me guess when the car fully warmed up (or not too cold out) the noise stops?
I'm totally NOT an expert on my Mazda (just bought it also) but I'd be surprised if it would be suspension/mount related, like Drizzoh mentioned, because it seems the noise will continue until you let go of the gas or stop turning. (although I've never tired it, the sound is too nasty)
guyforks 01-26-2014 01:20 PM
Glad I'm not alone. Friday night I didn't notice the sound at all and it was 25 to 30 degrees all day. The week prior was basically in the negatives. I'm going to check motor mounts and replace as needed. Were In For another round of arctic sub zeros so I'll check for the noise again tomorrow morning.
Snakes 01-26-2014 07:39 PM
A quick question @guyforks is the noise more like a crunching instead of grinding?
And I thought about the CV joint, but from my past experience a bad cv joint is more of a click/knock would that be true for the Mazda? (used to american vehicles, you know might be different)
Final Impact 01-26-2014 10:49 PM
Just park with the wheels turned and peak at the outboard boot. If torn and grease slung they almost always click in tight corners.
So, if yours all have the boots intact and they grind, that seems odd. Try gently leaning on the brakes while turning and see if it changes tone or pitch.
Anyway the brake pads are shot? Is it both sides or just one side and both directions?
Snakes 01-28-2014 10:52 AM
Well I don't know for guyforks, but for me it seems to come from the middle...and happens in either turning direction.
And like I said before it's a grinding noise, not a clicking noise (that would be associated with a CV joint)
Brandon Gum 12-19-2016 04:52 PM
I am having the same issue on my car as well. Just started to happen. Any comments anyone?
It is a grinding. Not a clicking
