cost to replace radiator? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 01-22-2014, 03:50 PM Thread Starter
was jacking up my car using the front jack point to swap my tires last night and when I went to go lower the car back down the jack slipped and punctured right thru the rad causing coolant everywhere.....
how much is it approx for a new rad and how many hours would a shop charge?
thanks
doubledeez is offline
post #2 of 5 (permalink) Old 01-22-2014, 03:59 PM
Drizzoh's Avatar
Quoted: 335 Post(s)
Groaned at 8 Times in 7 Posts
Send a message via AIM to Drizzoh Send a message via MSN to Drizzoh Send a message via Yahoo to Drizzoh
That's a fairly common thing to happen actually - which is one of the reasons I don't use the front jacking point (also my car is too low). But a Koyo rad is ~$150. It's a full day install though if you do it yourself on an MTX - not sure what extra steps need to be taken if you have an ATX since transmission fluid flows thru the bottom of the rad. A shop, no idea what they charge but it won't be cheap since you have to rip off the ENTIRE front end.
Andrew |
Drizzoh is offline
post #3 of 5 (permalink) Old 01-24-2014, 11:17 AM
kewlguy5's Avatar
Quoted: 6 Post(s)
Send a message via AIM to kewlguy5
If you have a 2.3L they say you can do it without removing the front end, but in my case I have a 3.0L and I had to remove the whole front end just to get to the radiator..
That being said you can pick one up at an autozone or o'reilly auto parts for about $167. Took me a few hours to install so save a day for the install.
Use this video as a guide:
This helped me with removing the front end. Good luck!
2006 Tungsten Grey Vii6 S
kewlguy5 is offline
post #4 of 5 (permalink) Old 07-18-2016, 02:32 AM
thanks
Just did this today! :/ did you end up taking it to a place. If so what did they charge. Thinking about doing it my self
Thanks
Alwayssomething is offline
post #5 of 5 (permalink) Old 07-28-2016, 02:18 AM
Quoted: 19 Post(s)
You can pick up everything here, but aftermarket will definitely be cheaper.
It also depends on the engine you have. As KewlGuy said, the 2.3 is pretty easy, and a shop probably wouldn't bill more than 3 hours for it. It would probably be close to 5-6 on the 3.0
thzpcs is offline
