How to: Installing Sender for gauges - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 25 (permalink) Old 02-03-2007, 06:12 PM Thread Starter
blackmagik_13's Avatar
Ok so I get like 1,895,345 x 81 PM's about "what do I need to install these gauges" and I figure, why keep putting all this info together in a PM when I can just post a thread about it and point whoever wonders in the right direction.
Also, it's tiring for me to have to look up the info a jillion times... really.
So here tis.
BEFOREHAND, understand this:
If I were to say "1/8 inch-27NPT", this means "1/8 inch inner diameter, 27 threads per inch, National Pipe Thread"... it's all one size.
ALSO, use teflon tape on most threading unless otherwise stated.
Preface: Here's a OLD SCHOOL video (I've gotten much better since...) of how to remove the map console lid thing... as stated, it's old school but it gets the message across and has been helpful in the past so, here tis:
Blackmagik Productions : Console Removal for Pods
Oil Temp: The area where you put the fitting (just below and to the left of the dipstick in the block [There's a silver colored Allen head pipe plug in the hole... remove it - that's where your oil temp sender and reducer bushing will go]) will be from 1/4 NPT to 1/8" NPT (Reducer bushing) The Oil Temp Sender is 1/8" NPT, which connects straight into the reducer bushing.
Oil Pressure: Stock sender located to the left of the oil filter must be removed. Must get 1/4" NPT to 1/8" NPT, some extra HYDRAULIC STAINLESS STEEL BRAIDED hose to extend upwards (must be hydralic SS hose or it will leak!!!). Place a T-fitting at the end of the hose that extends to the top of the engine bay, which needs to be 1/4" NPT for the stock sender, "xx" NPT (whatever size the hydraulic hose is), and "xx" NPT (whatever size your sender is).
Tranny Temp: Take your T fitting and place the two hose adapters in either side. Then in the bottom of the T, take your 1/8 adapter and install that. Then take your temperature sender and install that into the 1/8 adapter. You will need to use Teflon tape on the 2 hose adapters and the 1/8 adapter. Do not use any teflon tape between the sender and the adapter.(dagmz6s)
WARNING!!! Install the T fitting on the tranny line w/ the BLUE DOT!!! This is the exit line from the tranny, which will give you more accurate readings. The fitting is installed on the wrong line in the picture.
Before you finish this step you need to install something to ground the T. This will be done with a worm clamp and a terminal ring. You will place the terminal ring under the worm clamp and tighten it onto the T as much as possible. When you install the ground wire you will just clamp it into this terminal ring.
*sigh* That's the jist of it. Should help alot of people out. I'll try and look up sizes and all that jazz later, but for now... there it is. Out of my way.
kthnxmods sticky maybe?
blackmagik_13 is offline
post #2 of 25 (permalink) Old 02-03-2007, 07:33 PM
Axion's Avatar
Quoted: 4 Post(s)
werd dude, this should help out alot of people!
Axion is offline
post #3 of 25 (permalink) Old 02-03-2007, 07:35 PM Thread Starter
Should keep my Inbox from filling up as fast also
post #4 of 25 (permalink) Old 02-03-2007, 08:26 PM
Mazda6sMtx's Avatar
I'm installing the same gauges but all of mine are mechanical, so maybe I should do a different right up since everything is different.
There are also 2 of those allen head fittings on the block (look at pic) so you could use those instead of removing the stock sensor. Although the stock sensor is useless. I've had the light come on when my mech. oil pressure gauges reads above 15psi.
Mazda6sMtx is offline
post #5 of 25 (permalink) Old 02-05-2007, 04:06 PM Thread Starter
A different right up would be awesome There's no way I'd do mechanical gauges, as you're actually having fluids run into your car and to the gauge, which is a risk I wouldn't really want to take.
Also, your pic, 6i or 6s engine?
post #6 of 25 (permalink) Old 02-07-2007, 04:14 PM
what length hydraulic hose do I need to get?
Juelz8302 is offline
post #7 of 25 (permalink) Old 02-07-2007, 04:29 PM
Mazda6sMtx's Avatar
That pic is a 6s. It's right behind the throttle body. You have to remove the battery and the intake, to get to that part of the head easily. But even after all that work it's much easier to work with that the spot you suggested, I know because I used the spot you mention for my oil pressure gauge. And the line runs all the way around the car and finally up to the gauge.
MECHANICAL ALL THE WAY !!!!!
post #8 of 25 (permalink) Old 02-07-2007, 04:35 PM
the_gray_mazda6's Avatar
black, you are da man! i bet your inbox will definitely not be as filled with PMs now...
2005 Mazda6 3.0L MODS: Too many to list
2009 Kawasaki ZX-6R (Black) to go sh*tballs fast...
the_gray_mazda6 is offline
post #9 of 25 (permalink) Old 02-07-2007, 06:18 PM Thread Starter
what length hydraulic hose do I need to get?[/b]
I think I got just under 2ft or right around there. Take a measurement from where you're supposed to mount the plumbing and bring it up however far you'd like, it's your call. I barely gave myself enough room so I'd think a little too much is better than too little
post #10 of 25 (permalink) Old 02-08-2007, 11:07 AM
I think I got just under 2ft or right around there. Take a measurement from where you're supposed to mount the plumbing and bring it up however far you'd like, it's your call. I barely gave myself enough room so I'd think a little too much is better than too little [/b]
Aye Ya'll, where would I buy the hose from? I got all the other pieces.
Jaybo is offline
