I want to buy original headlights for my 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 05-23-2019, 04:59 PM Thread Starter
Quoted: 8 Post(s)
For a 2003 sports package with fog lights. I see all sorts of different ones. Which ones are the originals
yachtlanding is offline
post #2 of 8 (permalink) Old 05-23-2019, 07:07 PM
Mz6GreyGhost's Avatar
Quoted: 836 Post(s)
Groaned at 6 Times in 3 Posts
The versions you want are the models with the fog lamps integrated into the headlamp units themselves (between the turn signal and the high beam reflector). Those were standard on 1st-gen pre-facelift, sport-model 6s.
Mz6GreyGhost is offline
post #3 of 8 (permalink) Old 05-24-2019, 02:23 AM
Quoted: 434 Post(s)
I installed integrated fog lamps in my non-sport 2003-2005 model. It was shipped with blanks where the lamps normally sit. I wired them a little differently because the original fog switch, which is mounted on the turn-indicator stalk, was being used by the OEM option lower fogs.
All you basically need it the stalk mounted switch and the projectors. All the wiring and fuse/relays are already there.
Mozz-D
DrFeelGood is offline
post #4 of 8 (permalink) Old 05-24-2019, 06:58 AM
DJ Raydiate's Avatar
Quoted: 93 Post(s)
What's wrong with the current lights? Are they broken or fogged up?
Ray.
2003 6s
DJ Raydiate is online now
post #5 of 8 (permalink) Old 05-24-2019, 04:57 PM Thread Starter
Quoted: 8 Post(s)
Anyone know which are the right ones for my 2003 Mazda 6 sports package with integrated fog lights. Thanks
post #6 of 8 (permalink) Old 05-24-2019, 05:10 PM Thread Starter
Quoted: 8 Post(s)
I have headlight cover lenses but nobody wants to install them.
post #7 of 8 (permalink) Old 05-25-2019, 12:51 AM
Quoted: 434 Post(s)
Right side integrated fog lamp = GJ6A-51-6A1
Left side integrated fog lamp = GJ6A-51-69X
Headlamp switch w/fog lamps = GJ6H-66-122
Plus 8 small sheet metal screws to hold them in place.
I got all my stuff from the salvage yard for about $40
It takes about 2hrs to install.
And when you want to replace the lenses the video below shows using a heat gun. An oven can also be used to soften the sealant
Mozz-D
post #8 of 8 (permalink) Old 05-25-2019, 07:22 AM
Quoted: 93 Post(s)
You can also make your own retrofit hot box for dirt cheap and do the lenses yourself. It's easier than you think.
In the hot FL sun, I don't even need an oven or a heat gun to open the lights up.
Beings that you have the lenses, I'd look up "how to retrofit headlights" , "demon eye install" , "halo/angle eye install", or "how to open up headlights. All of these search results will show you how to open the lights. Once open, you can clean the channels really good and use the sealant of your choice.
I will add that if these are aftermarket lenses like the ones I have (not installed yet) it would be a good idea to have them clear coated with 2k clear or another type of automotive clear that has uv protective properties. This should help with yellowing and hairline fractures.
Ray.
2003 6s
Similar Threads
Chinese headlights are bluer than stock GT Mazda6Suspension Mazda6 (Atenza) 2 03-18-2018 11:35 AM
Aftermarket GT style headlights for sport or touring models etbis Electrical / HVAC 12 01-04-2018 04:36 PM
Swapping halogen headlights with the GT headlights Cheezeman Electrical / HVAC 2 04-29-2016 11:04 AM
HID Replacement Headlights vs Non HID too2buff Electrical / HVAC 4 06-15-2008 10:43 PM
Headlights are unfixable ITIongo Mazdaspeed6 11 02-02-2008 06:32 PM
