Need help-dash haywire-won't start. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 28 (permalink) Old 04-19-2019, 12:46 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
I'm stranded...Drove for 2 miles and parked the car. Tried to start it again and the dash went nuts and it won't start. Now I get nothing; no dash lights or accessories.
Help.
2006 Mazda6, 3.0L v6, six speed auto (all stock, and loving it.)
TampaBay6 is offline
post #2 of 28 (permalink) Old 04-19-2019, 12:51 PM
Archerfish's Avatar
Quoted: 151 Post(s)
I encountered this with a loose battery terminal and a dead battery.
Archerfish is online now
post #3 of 28 (permalink) Old 04-19-2019, 01:09 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
Terminals are tight and I get 12.5 volts at the battery.
post #4 of 28 (permalink) Old 04-19-2019, 02:06 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
I put a charger on the battery and the voltage meter shows 12.9. Everything is normal when I turn the key to ACC, but then nothing when I turn to Start. The dash goes black.
Then, after I turn the key to Off and remove it, the tach and speedo needles do a complete swing clockwise and then return.
post #5 of 28 (permalink) Old 04-19-2019, 03:45 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
Just picked up, and installed a new battery. Same problem.
Any ideas guys?
post #6 of 28 (permalink) Old 04-19-2019, 03:46 PM
DJ Raydiate's Avatar
Quoted: 103 Post(s)
It sounds like a ground issue or corrosion. It could also be a bad battery not providing enough cranking amps even though it's holding a charge. Mine did it when i first got the car used. It had a taller battery than factory and was hitting the hood. Needles went everywhere and was acting funny.
Ray.
2003 6s
DJ Raydiate is offline
post #7 of 28 (permalink) Old 04-19-2019, 03:48 PM
Quoted: 103 Post(s)
Oh nevermind about the battery, you responded while I was typing that lol. I'd definitely check the grounds. Also may sound funny but while there make sure the starter power wire and the starter itself is tight so it's making a good ground.
Ray.
2003 6s
post #8 of 28 (permalink) Old 04-19-2019, 04:22 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
My girlfriend just texted and said "it's probably your alternator." I'll just say "yeah."
But I don't think it's the alternator. Not going to tell her that, because I'm on thin ice as it is...
post #9 of 28 (permalink) Old 04-19-2019, 06:14 PM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
Situation is this: Turn key to ACC and the dash lights up like normal. Turn key to START and everything goes black (and there's no starter noise or clicking.) Turn the key back to ACC and everything remains black. Turn the key OFF and remove, and the gauge needles swing all the way to the right and then back.
Thought it might be the battery so I bought a new one and installed it today. No improvement.
post #10 of 28 (permalink) Old 04-19-2019, 11:22 PM
tickerguy's Avatar
Quoted: 925 Post(s)
Groaned at 7 Times in 7 Posts
Check the grounds.
DJ Raydiate likes this.
tickerguy is offline
TampaBay6 (04-23-2019)
Similar Threads
Green key light doesn't light up on dash when pressing on brakes Seiya Mazda6 (Atenza) 6 09-27-2016 07:41 PM
2004 mazda 6 doesnt start coltonmt17 Mazda6 (Atenza) 0 10-26-2015 10:59 PM
Mazda Mobile Start service outage matthewf01 3rd-Gen 27 09-13-2015 04:31 PM
'54 Mazda TS Diesel won't start ge1971 Newbie Section 0 01-23-2013 03:27 PM
2011 6 Won't Start (Red Start Button + Red Key Light on Dash) Craigy1D Electrical / HVAC 4 12-24-2012 03:36 AM
