2018 Homelink Install Issues - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 01-19-2019, 06:46 PM Thread Starter
Quoted: 57 Post(s)
Trying to install a Homelink Mirror in a 2018 Sport but running into multiple issues.
1. The wiring is different from the previous gens and do not work with the install kit. So I had to run the wire all the way to the fuse box.
2. Normal Homelink Mirror won't clear the sensor covers so I bought a longer GNTX-453-2
3. The sensor cover won't clear the Mirror so I might have to cut the wings.
Does anyone have a picture of the Homelink mirror installed on a 2018 under the cover? Would like to see the wire routing and if I need to break out the Dremel.
guy989 is offline
post #2 of 7 (permalink) Old 01-20-2019, 10:35 AM
Chazzy J's Avatar
Quoted: 74 Post(s)
Which homelink are you trying to install? The older one with a black frame around the mirror, or the newer frameless mirror that comes stock on the higher model 6?
2018 Mazda6 Signature
- Soul Red/Parchment
Chazzy J is offline
post #3 of 7 (permalink) Old 01-20-2019, 01:20 PM Thread Starter
Quoted: 57 Post(s)
Trying to install the older black frame one with extended mount from another that cleared the GJ sensors I believe.
guy989 is offline
post #4 of 7 (permalink) Old 01-20-2019, 04:26 PM
Chazzy J's Avatar
Quoted: 74 Post(s)
That's probably where the issue is. Different homelink mirror in the car for 2018. I'm sure you can still get it to work, but as you've found, it is unfortunately not plug and play as you have discovered
Chazzy J is offline
post #5 of 7 (permalink) Old 01-20-2019, 05:43 PM
Mz6GreyGhost's Avatar
Quoted: 819 Post(s)
Groaned at 6 Times in 3 Posts
This may not be the issue. My '18 GTR has the Homelink with the framed mirror, similar to the one used in my 2nd-gen. I believe only the Signature uses the frameless mirror...
I can get pics of my mirror installed from the factory, and post them up, if it may help...
Mz6GreyGhost is offline
post #6 of 7 (permalink) Old 01-20-2019, 07:23 PM Thread Starter
Quoted: 57 Post(s)
Thanks for the offer but problem solved with a couple of cut off wheels and a Dremel. Here are some pictures of the cuts needed for anyone in the future that might have the same issue. Worth it for 1/5 the cost of a mirror from Mazda.
guy989 is offline
post #7 of 7 (permalink) Old 01-20-2019, 08:19 PM
Chazzy J's Avatar
Quoted: 74 Post(s)
Oh my fault guys. I thought the frameless came in all 2018s. Makes sense now
Chazzy J is offline
