Hello,
My 2006 Mazda 6 - 3.0L is having issues with the cooling fan (or so I think).
Essentially, when I turn the ignition on, drive it down the block and back with the A/C on it doesn't seem to work well. I went home and popped the hood and pressed the A/C button and then looked at the fans. The fans come on but go quite slow. Then they stop. Then they come back on. Then they stop etc.
What would be the first thing to check? Could a bad fan control module be the issue? I already replaced it (with a cheap one). I am willing to get a dealership part if that is the problem but would like to ensure that this is the issue first before spending the money on an expensive part.
Thanks,
Thanks,
