2004 Mazda 6 Wagon Tail Light Assembly question - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 12-09-2017, 10:15 PM Thread Starter
Quoted: 8 Post(s)
I have the 6 wagon, and I was wondering what the compatibility from other 6 models are?
The outer lense is a single circle, separated into the brake / tail light, and the turn signal. The lift gate lenses i would change as well, but more to match the outer.
I wanted to change them over to the newer style, clear lense, black back, dedicated amber turn signal.
Does anyone know if the assembly from a standard sedan will work on the wagon?
Or does it have to be from a hatchback, or wagon?
The attached pictures. The red car has the tail lights my wagon has. The silver is the type I want to change out too.
Sent from my SM-G935V using Tapatalk
joe.skelly is offline
post #2 of 6 (permalink) Old 12-09-2017, 11:03 PM
Mz6GreyGhost's Avatar
Quoted: 785 Post(s)
Unfortunately, the tails between the sedan/5-door and the wagon are not interchangeable.
You have a couple of options if you want to "black out" the surrounding glass. One is to find a set of wagon tails from a '06-'08 (which will swap out with your current tails without issue). That's exactly what I did with my sedan. Your other option is to paint them yourself with some type of tint.
Mz6GreyGhost is offline
The Following User Says Thank You to Mz6GreyGhost For This Useful Post:
joe.skelly (12-09-2017)
post #3 of 6 (permalink) Old 12-09-2017, 11:22 PM Thread Starter
Quoted: 8 Post(s)
Thank you. That's why I asked, I didn't want to get the regular lights, only for them not to fit.
Did you order yours online? Most of the sites I've found don't really have the sub models for filtering (sedan, hatchback & wagon)
post #4 of 6 (permalink) Old 12-11-2017, 09:30 AM
Quoted: 785 Post(s)
At the time (back in '07), I had a connection with a Mazda dealer that was able to get me the tails at cost.
SOME Mazda dealers may still offer them online, but since they're from a previous generation, you may be better off checking out a used car parts supplier, either online or a junkyard.
joe.skelly (12-11-2017)
post #5 of 6 (permalink) Old 01-23-2018, 01:17 AM
Quoted: 19 Post(s)
If you want to pick them up from an online dealer, RMP has them for pretty cheap. They're about $110, and you can get the blacked out wagon versions too, which I think are the GR6K variant.
thzpcs is offline
post #6 of 6 (permalink) Old 01-23-2018, 01:46 AM
babyluv2's Avatar
Quoted: 21 Post(s)
Have you checked eBay?
Sent from my KFFOWI using Tapatalk
babyluv2 is offline
