Ok, so I had my local tint shop install a “3x lock ALCA compustar” and a “DC-3” module. I am able to retain my OEM keyfob and activate remote start by doing Lock, Unlock, Lock. Here’s where my issues begin:
1. I can’t get in the vehicle by hitting the unlock button on the door handle. I must use the keyfob. Post remote start install, completely have lost the ability to use the door lock buttons on the handle, regardless if utilizing remote start or not.
2. Once I open the door, vehicle is still on and all, which is good. However, I see an error message on the dash that says several things like, “Keyless System Malfunction,” “Key not detected,” and “Key FOB battery low. Hold key close to start button.”
3. In addition, my camera is showing up very “staticy” on the screen. Almost as if the monitor is losing the signal to the camera. Not very drastic, but definitely noticeable. Almost like when back in the day, the coaxial wire to the back of your tv wasn’t screwed in all the way.
Secure takeover has only worked 2 out of 10 attempts. I have to literally put the key fob to the “Push to start” button and hope it catches on. Every single time I have put my foot on the brake pedal, the car turns off, regardless if I had the fob on my lap or touching the “push to start button.”
Also, during a “non-remote start” entry, I can no longer just hop in the car, foot on brake pedal, and hit the push to start button while the key is in my pocket, nearby, etc. I literally have to touch the key fob to the start button every single time, whether post remote start or just regular manually starting myself.
Any thoughts, advice? Tint shop is closed until Monday. I had my cousin pick up the car today so I wasn’t able to bring these issues up.
