Hey, sorry to bring up an old thread (joined the forum last week). I have these installed too but I had a question. Did you have to buy a new housing cap when you put the HIDs in? It has that H7 cover with the three pins that lock in once you turn the cover but fitting the HID bulb wires would obviously prevent the cap from fitting. Wondering how you got around this.
Also for anyone interested, if you don't want to do the jumper wire to disable the DRLs, you can just turn it off. There's an awkward combination you need to activate and it keeps the DRLs off. The high beams will still work. I'm new so I can't paste the link but search for "How turn off drl." One step isn't mentioned, which is at the end after you do the last sequence, you have to release the parking brake first then the brake pedal and turn off the car for about 5 seconds. Then turn it on as normal and as soon as you put it in drive, you'll notice the DRL's are now off.
