Smart Rover 9" Android Head Unit. - Page 31 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 33Likes
post #301 of 399 (permalink) Old 04-19-2017, 09:28 PM
Quoted: 70 Post(s)
Originally Posted by fredaroony View Post
No, you only hear the beeping but they are linked to canbus from what I understand. The newer stock head units display the parking sensors
pretty sure iqnavi does support displaying the parking sensors. They show it in one of their demo videos.
Skip to 11 minutes -
I have iqnavi on my unit, but no parking sensors, so I can't confirm if this works or not.
Hisma is offline
post #302 of 399 (permalink) Old 04-19-2017, 09:29 PM
Quoted: 70 Post(s)
Originally Posted by DphAmT View Post
Hi! I'm trying to install my backup camera but I'm kind of stuck.
I connected the ground wire to the head unit side connector. What got me confused is the blue/white wire that you said to connect to the AMP-CON wire. That wire leads to the Canbus Decoder module. The part I'm stuck with is the blue/red wire. I tried testing to connect it to the factory harness red/white wire but nothing happened. I'm not comfortable with cutting into the factory harness so I tried to just stick the wire in. That didn't work but I noticed a white/red wire in the same factory harness. I tried sticking the 12v to 6v blue/red wire in there too but that didn't work as well. I'm pretty stuck.
@Hisma, @chutoyy, @Donkey Grundle, @Interlukens 1. Please help!
someone managed to get backup cam working on manual transmission and I think he posted his results somewhere. Wasn't me, unfortunately, so I can't help. Sorry.
Hisma is offline
post #303 of 399 (permalink) Old 04-19-2017, 09:33 PM
Quoted: 70 Post(s)
Originally Posted by OCTOGONPC View Post
Someone posed a question on this device, and thought about you guys!
Q: Can this device be used in the car to play audio
https://www.amazon.com/Alloyseed-Alu..._cd_al_qh_dp_i
A:
I just tested my 7-Port Alloyseed device in my 2014 Mazda 6, and when one (1) USB Drive was plugged in, it played just fine, however I got a USB Read Error when I added a second USB Drive. I brought this unit for my 4K Sony Android TV, and it works with multiple items installed. SO, if your head unit it a Smart Unit (like one powered by Android), and can see Multiple drives / devices, this should work very well.
Love to know IF this can be done. Peace!
Yes it should. You have to see the power requirements of the device you are powering to be sure though. USB 2.0 (which is in these HUs) maxes out at 500mA. So you cannot plug in devices that draw any more than that. A standard thumb drive wouldn't have anything to worry about.
Hisma is offline
post #304 of 399 (permalink) Old 04-19-2017, 10:31 PM
Quoted: 19 Post(s)
Groans: 6
Skip to 11 minutes
Brilliant, thanks for that! I'm keen for my unit to turn up.
fredaroony is offline
post #305 of 399 (permalink) Old 04-21-2017, 06:09 AM
Quoted: 19 Post(s)
Groans: 6
The Tomtom GO app works perfectly if anyone wants to know.
post #306 of 399 (permalink) Old 04-22-2017, 04:48 AM
Quoted: 19 Post(s)
Groans: 6
Parking sensors display for front and rear plus the actual sensor that is going off.
post #307 of 399 (permalink) Old 04-24-2017, 01:54 PM
Quoted: 18 Post(s)
Anyone having issues with the back-up camera feed cutting out? I have a 6-speed so the seller had rewired the adapter to ensure the camera was functional. The feed always comes on when I go into reverse but when I start turning my steering wheel, the feed cuts out and comes back. I have checked my connections over and over and I can't seem to figure it out.
akgos11 is offline
post #308 of 399 (permalink) Old 04-24-2017, 07:47 PM
Quoted: 19 Post(s)
Groans: 6
Mine has gone black a couple of times but not in the middle of using it.
post #309 of 399 (permalink) Old 04-27-2017, 12:11 AM
Quoted: 19 Post(s)
Groans: 6
it works very well. just one simple task to start wifi tether upon bt connection & stop wifi tether when bt disconnects.
it takes about 20-25 secs to cold boot the unit, and another 5-10 secs for the wifi to connect. So at most 35 seconds from start. Typically I get wifi right around the same time my GPS locks.
As I said I experimented w/ placing the GPS in various locations. The HU comes w/ an app that tells you how strong your GPS signal is. I get best signal and fastest lock placing my GPS at the center of my windshield next to my rearview mirror. So when you go to mount your external mic I'd run the GPS along with it.
I mounted the GPS in the same location but find it takes very long time to get a lock and often loses the lock throughout the trip. My Tomtom unit in the car locks MUCH faster and never loses lock.
I checked the connection last night and all good
Anyone else have weak GPS signal issues?
post #310 of 399 (permalink) Old 05-11-2017, 03:03 PM
With this being over a 12 month old post, does anyone know of a head unit similar to this but with a better spec?
Sent from my SM-G955F using Tapatalk
Langy01 is offline
