Smart Rover 9" Android Head Unit. - Page 22 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 33Likes
post #211 of 399 (permalink) Old 10-27-2016, 09:34 AM
Donkey Grundle's Avatar
Quoted: 439 Post(s)
Groans: 22
The built-in mic worked for me. I was able to make a call into the house and test with/without the external mic and found it carried voice a little better with the external mic.
The buttons around the command knob also worked for me out of the box:
Audio > Audio Settings
Nav > set to your default nav app (Waze, Google Maps, etc)
Phone > Phone call
Setup > Settings screen
Back buttons both work
Push knob to pause/play music
Donkey Grundle is offline
post #212 of 399 (permalink) Old 10-27-2016, 09:41 AM
pub
pub's Avatar
Quoted: 8 Post(s)
Phone > Phone call
Thats strange..
I downloaded a sound recording app, and it records my voice fine, but if i call somebody they don't hear my voice.
Maybe i need to unplug the external mic to use the internal for calls?
The buttons don't work (except the ones on the wheeldrive), tried to assign them but nothing.
I have this unit from smart rover:
https://www.aliexpress.com/item/9-HD...603062675.html
pub is offline
post #213 of 399 (permalink) Old 10-27-2016, 11:58 AM
Quoted: 70 Post(s)
Originally Posted by pub View Post
The hifi guy connected it, to the unit's aux port (says mic). I wasn't there because of work, but i'll take back. Thank you for the post about the buttons, i missed that thread
check and make sure it is still connected. It is possible that it disconnected accidentally when he tucked the wires away. It should be working if it's all connected up.
as for the buttons, most guys here didn't have any issues w/ getting the buttons working, but I did. I have the 8" screen that looks almost identical to stock. In any case, it is not difficult to hardwire the buttons to work if it isn't working via canbus. You just have to tap a couple wires off the main harness... one to key 1, one to ground. Then you can use the configuration tool to set the buttons to whatever you want, which is nice. Just show your hi-fi guy my guide I posted and he shouldn't have an issue.
Hisma is online now
post #214 of 399 (permalink) Old 10-27-2016, 12:07 PM
Quoted: 70 Post(s)
Thats strange..
different functions. when you are recording your voice in an app, you are interfacing with the android unit itself. When you are talking on the phone, you are interfacing with the bt system, which is actually independent of the android system. BT communicates via the MCU, which also manages your audio connections, power, etc. The MCU communicates with the android system via serial. It's pretty janky, but as of now there is no pure android unit that has bt natively integrated. (that is why certain apps won't install via the playstore if they require bt... the os thinks you don't have bt bc it can't see it).
Anyway, the point of my post is that if your bt is not correctly configured, it won't work. So if your mic is correctly connected, also check your bt settings. I think someone here already posted what their settings are. make sure yours match.
Hisma is online now
post #215 of 399 (permalink) Old 10-28-2016, 05:19 AM
pub
pub's Avatar
Quoted: 8 Post(s)
Oh that's new to me, i was soure there is an internal bluetooth module in the unit, because the bluetooth module wants to pair with my phone (i deleted that connection from the phone). The old connection called "mazda", since we installed the new hu i can connect to "Smart-Rover". I'm not able to ignore these requests on my phone (it's not rootable so i cannot change the mac address of the bluetooth adapter, renaming didn't help), and i cannot reset the bluetooth module, so maybe the solution is to put back the old hu and delete the connection with my phone
I checked the bluetooth settings multiple times earlier, these are the same settings what i saw here in this thread. We'll check the wires and the microphone too.
Someone said the external mic has better sound quality then the internal for calls, so can i use the internal? I didn't find the option for this, maybe when i plug in the external mic the internal is going to disabled?
ID:	195474   Click image for larger version
ID:	195482   Click image for larger version
pub is offline
post #216 of 399 (permalink) Old 10-30-2016, 09:47 PM
Quoted: 57 Post(s)
I was having low signals with WI-FI and GPS so I decided to move them from the glove box and back of the unit respectively. Used to get 1 bar WI-FI to 3 bars and 8 satellites to 13.
Just pop of the center speaker cover, remove the stock GPS and avoid placing on any holes that the grill uses to clip in.
guy989 is offline
post #217 of 399 (permalink) Old 11-01-2016, 08:53 PM
Quoted: 20 Post(s)
Hey @guy989, @Hisma, @mendozahtc you guys mentioned you installed IQ Navi v0.1.25. I have two questions for you guys and anyone else who may have installed it.
1) Have any of you updated to IQ Navi v0.1.29? https://youtu.be/z-H6xJKEs50?t=9m10s
2) When the rear cam is on, the image appears fine. It's a little easier to see the blur since the image is stretched onto a bigger screen; however, the reverse parking guidelines are disproportionally pixelated. It's a little strange because those yellow/red lines are software rendered. They're not coming from the camera. On the stock SmartRover firmware it's as if the HU is rendering them at an unusually low resolution. My question to you guys with the IQ Navi firmware is do those guidelines look sharper/anti-aliased/higher-res than on the stock SmartRover firmware? The video above running IQ Navi v0.1.29 shows the lines render sharp and they can even be customized (around the 9min10sec mark).
Name:	reverse lines composite.jpg
Habaku is offline
post #218 of 399 (permalink) Old 11-01-2016, 09:29 PM
Quoted: 70 Post(s)
interesting, looks like I need to update. The pixelation is not because it is rendered at a lower resolution, it's that the original screen is much smaller, so the pixels are not as stretched as they are on our larger screens. The pixel density is higher on the smaller screen.
I'll try out 1.29, once I can find a place to download it.
Hisma is online now
post #219 of 399 (permalink) Old 11-01-2016, 10:34 PM
Quoted: 57 Post(s)
1. Right now only IQ Navi v0.1.25 is free to download and IQ Navi v0.1.29 cost $25 to the developer.
2. Assuming that you have installed the latest available IQ Navi firmware, you can get those lines by enabling it in the "Extra settings under "Reverse Line Ruler". Note that it will overlay over the stock reverse lines. It also has a "Reverse Trajectory" option with another set of lines but doesn't work on my Sport. Might work on a Grand Touring due to the AFS.
guy989 is offline
post #220 of 399 (permalink) Old 11-04-2016, 06:51 PM Thread Starter
MadStyle's Avatar
Quoted: 251 Post(s)
Groaned at 3 Times in 2 Posts
Can someone send me the original OS build that came with the radio? apparently updating to IQ Navi also makes it your primary OS, so when doing a Factory Reset from settings, IQ Navi reinstalled as fresh.
MadStyle is offline
