'14 Nav/Radio/Head Unit Petition for S/W Update! - Page 104 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 13Likes
post #1031 of 1307 (permalink) Old 10-29-2014, 09:07 AM
mazda6guy's Avatar
Quoted: 70 Post(s)
Originally Posted by Atxyde View Post
I don't think that is a memory/cache clearing thing. I think that the USB/BT module stay alive for a couple of seconds after shutting off the car for some reason.
I'm guessing this has to do with allowing the option to keep the music playing after parking the car and shutting it off, which in itself is sort of clunky. When you park, you have to press the Engine On/Off button twice quickly, and if you don't do it slow/fast enough correctly, the car will simply shut everything off and you have to hit the Engine On button and wait for the headunit to boot again and connect. But if done correctly, everything will turn off for about 2 seconds, and then the head unit screen will power back on and will resume playing from the last source (i.e. FM, BT, Pandora), while the car is in ACC mode. Pandora is notoriously unreliable when doing this though, as it generally produces an on-screen error when the screen comes back on. You'll notice that the connection to Bluetooth is almost instant when the screen powers on, so it seems as what your describing is happening here.
This is was different from my previous vehicle (2012 Nissan Altima) in which you simply held the Engine On/Off button for two seconds and the engine would shut off but the headunit would continue playing without any pause or interruption, and the car would go into ACC mode.
Why Mazda decided on this clunky procedure, I have no idea.
Current Mazda
2018 Mazda6 Signature
Machine Gray Metallic
Previous Mazdas
2014.5 Mazda6 GT
Meteor Gray Mica
2008 Mazdaspeed3 GT
Sunlight Silver
2006 Mazdaspeed6 GT
Velocity Red
2003 Mazda6 Sport V6
Glacier Silver
1996 Mazda MX-6 V6
Emerald Green
mazda6guy is offline
post #1032 of 1307 (permalink) Old 10-29-2014, 11:06 AM
Quoted: 6 Post(s)
Or, if you put the gear in neutral or reverse (while brake is firmly depressed) and then press the off button, the music will continue to play. Then you can safely put the gear in park. Which, I think, is just as clunky. Haha.
joejdsn is offline
The Following 2 Users Say Thank You to joejdsn For This Useful Post:
Gavintech (10-29-2014), mazda6guy (10-31-2014)
post #1033 of 1307 (permalink) Old 10-29-2014, 04:08 PM
Quoted: 196 Post(s)
Groans: 20
I use the Neutral method almost every day.
2015 Mazda6 Grand Touring.
2003 Mazda6 S Sedan. MTX.
Gavintech is offline
post #1034 of 1307 (permalink) Old 10-29-2014, 05:35 PM
Atxyde's Avatar
Quoted: 41 Post(s)
I do this as well when I'm going to be out of the car for a short period. The problem is the car doesn't lock itself when only the ACC is on.
atxyde
2014 MAZDA 6 GT / Tech Package
Atxyde is offline
post #1035 of 1307 (permalink) Old 10-29-2014, 05:59 PM
Quoted: 196 Post(s)
Groans: 20
Huh? I put it in park when I get out of the car.
post #1036 of 1307 (permalink) Old 10-29-2014, 07:51 PM
Atxyde's Avatar
Quoted: 41 Post(s)
I put it in park as well but my 6 walk away lock feature doesn't work if I leave the ACC on. It start chiming indicating that the fob is not inside. If I try to lock it using the door's button it doesnt lock until it is completly shutted off.
atxyde
Atxyde is offline
post #1037 of 1307 (permalink) Old 10-29-2014, 08:21 PM
dellbx's Avatar
Quoted: 34 Post(s)
Last night I came to the realization that I will not be buying my '15 6 at the end of the lease. The trigger was trying to use voice commands to make a simple phone call. It is such an ordeal. On my old car all I had to do was press a button and say "call Bob"... Nothing else.
Even if I wanted to jump through all the hoops on the 6's voice command system the blessed thing gets it wrong half the time.
That combined with the screwed up HU there is no way I will be able to put up with this for beyond lease end
dellbx is offline
post #1038 of 1307 (permalink) Old 10-30-2014, 11:46 AM
Quoted: 25 Post(s)
Leaving the car on ACC is the equivalent of leaving your keys in an ignition. The car is doing what it is designed to do, the lock button on the fob was not made to turn the car off.
ZoomZoomZealot is offline
The Following User Says Thank You to ZoomZoomZealot For This Useful Post:
Gavintech (10-30-2014)
post #1039 of 1307 (permalink) Old 10-30-2014, 08:19 PM
Quoted: 196 Post(s)
Groans: 20
Why would you leave your car on and walk away from it?
The Following User Says Thank You to Gavintech For This Useful Post:
nobouncecap (10-30-2014)
post #1040 of 1307 (permalink) Old 10-31-2014, 12:09 AM
Atxyde's Avatar
Quoted: 41 Post(s)
Let me explain myself with this scenario. The HU takes 4 to 5 minutes to show my usb music. After that I have to search for the artist/song that I want to listen because the stupid thing can't remember ther last song I was listening. So, imaging making short stops, like going to the gas station, and repeating this procedure everytime I start the car waiting 4 long minutes. Working arounf the issue I do as others members are doing. Shutting the car off in neutral leave the HU powered up and then I put the car in Park. It would be nice if I could lock ther door, at least manually, during those short periods of time that I will be out the car. I know the car is working as it is suposed to do but is a pain to wait all that time to listen my favorite music.
atxyde
Atxyde is offline
The Following User Says Thank You to Atxyde For This Useful Post:
boneznet01 (10-31-2014)
