Blower motor not working - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 12-19-2011, 08:00 PM Thread Starter
eizzle's Avatar
Send a message via Yahoo to eizzle
So I've replaced the blower motor and resistor and no luck. I checked every fuse in the car and under the hood. I've pulled all the relays and swapped them around. I guess it's down to the switch. Anybody ever replace this? I assume it's under the radio? What is the relay in the cabin fuse panel for?
Balance shaft delete Injen Intake M-1 Front Bumper Custom exhaust Timing Mod Custom Interior 8000K DDM HIDs Tinted Taillights and Turnsignal lenses Black Headlight housings Eibach Pro Kit springs
Soon: RX-8 Wheels RX-8 Seats Get rid of the primer...
eizzle is offline
post #2 of 4 (permalink) Old 01-01-2012, 12:40 PM
Quoted: 145 Post(s)
Groans: 5
Groaned at 8 Times in 6 Posts
Did you provide a direct ground for the motor?
If it worked, could also be the climate control module ... unusual
helpful link:
http://forum.mazda6club.com/3310642-post2.html
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is offline
post #3 of 4 (permalink) Old 01-01-2012, 12:43 PM Thread Starter
eizzle's Avatar
Yeah, actually that relay in the drivers side kick panel is for the blower motor, the whole system actually. I hate when it's so simple after I made it so hard...
eizzle is offline
post #4 of 4 (permalink) Old 01-01-2012, 11:51 PM
Quoted: 145 Post(s)
Groans: 5
When I directly grounded the blower motor and it worked, that eliminated the blower relay and the ign switch as problems (that relay in the kick pannel is burried and would be tough to remove).
That left the climate-control-unit not requesting blower use, or the ACC PWM speed unit (the speed resistor pack for maual systems). My issue was a bad PWM speed control. After I did it, I should have let the dealer do it for the 1/2 hr labor charge.
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is offline
