Maz6 H.i.d. Noob Question - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 09-01-2007, 02:23 AM Thread Starter
Hi guys,
Just wondering if this work; because i dont wanna drills the ballasts onto the chasiss, is it possible to mount the ballast underneath the headlight then run a wire connect the ballast to the chassis to ground it. btw, i got the new GT hid kit so the ballast is in metal housing with the mounting holes
tonymeman_au is offline
post #2 of 5 (permalink) Old 09-01-2007, 03:58 AM
Don't know about the GT kit but people have mounted the ballasts of other kits under the headlights...
Also, can't you just connect the ground to the stock grounding wire thing?
Lapis6S is offline
post #3 of 5 (permalink) Old 09-01-2007, 07:56 AM
mmarfan's Avatar
Hi guys,
Just wondering if this work; because i dont wanna drills the ballasts onto the chasiss, is it possible to mount the ballast underneath the headlight then run a wire connect the ballast to the chassis to ground it. btw, i got the new GT hid kit so the ballast is in metal housing with the mounting holes[/b]
Yes you can; I have done that. Matter of fact that's the most recommended place IMHO. If you ever have to take the headlight out, you won't have to unhook a bunch of crap.
The new:
The old:
mmarfan is offline
post #4 of 5 (permalink) Old 09-01-2007, 11:51 PM
Fouler's Avatar
Send a message via MSN to Fouler
Or you can get Hardcore like I did and drilled holes into the chassis I wish I took pics of my install it's Bad Ass I have one where my air box resonator was and one of to the side of the windshield wiper resevoir
-Silverfox™
If you want some muscle but don't want to spend the money. Watch This Clip
Don't end up like that just spend the damn money!
Fouler is offline
post #5 of 5 (permalink) Old 09-02-2007, 02:38 AM Thread Starter
Or you can get Hardcore like I did and drilled holes into the chassis I wish I took pics of my install it's Bad Ass I have one where my air box resonator was and one of to the side of the windshield wiper resevoir[/b]
whats so hardcore drilled holes on the chassis??? i bolted mine onto the chassis today, but will the ballast get wet?
