Hid Kit Causing Fuse To Blow - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 08-14-2007, 04:26 PM Thread Starter
Send a message via AIM to ChrisBlue6s
Unhappy
Hey guys. I finally got my APEXCONE 5000K 50watt HID kit installed, looks great, pics coming soon, maybe tonight. Any way. I've had the it knstalled since Saturday and have gone through 2 sets of fuses. I'm 100% positive that all connections are intact and that there is no bare metal/wire showing. I contacted the RPM store and they recommended that I go up to a 15amp fuse and see if this solves the problem, otherwise they recommend to purchase a complete wiring harness that they have in stock. Now, stock fuses are 10 amps, 1 fuse per headlamp. theRPMstore also said that the ballasts draw 6 amps of power when turned on, so a 10 amp fuse should be okay, rigfht? I don't want to fry my ballasts or bulbs. What do you guys think I should do? Thanks. Also thanks to those of you who helped me during the install.
ChrisBlue6s is offline
post #2 of 7 (permalink) Old 08-14-2007, 06:33 PM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
Hey guys. I finally got my APEXCONE 5000K 50watt HID kit installed, looks great, pics coming soon, maybe tonight. Any way. I've had the it knstalled since Saturday and have gone through 2 sets of fuses. I'm 100% positive that all connections are intact and that there is no bare metal/wire showing. I contacted the RPM store and they recommended that I go up to a 15amp fuse and see if this solves the problem, otherwise they recommend to purchase a complete wiring harness that they have in stock. Now, stock fuses are 10 amps, 1 fuse per headlamp. theRPMstore also said that the ballasts draw 6 amps of power when turned on, so a 10 amp fuse should be okay, rigfht? I don't want to fry my ballasts or bulbs. What do you guys think I should do? Thanks. Also thanks to those of you who helped me during the install.[/b]
Pay the extra $30 and get the relay harness
2010 F-150
1990 F-150
djquik1 is offline
post #3 of 7 (permalink) Old 08-14-2007, 06:52 PM
Poet's Avatar
Quoted: 17 Post(s)
What DJ said...I haven't gotten mine yet cuz I screwed up when I ordered my kit...And I rarely drive at night so I'm not in too much of a hurry, but in the next month or 2 I will be switching it...Definitely before Daylight savings ends....But you should def get the harness...From what I heard it's pretty simple to install and takes maybe an hour or so.
Poet is offline
post #4 of 7 (permalink) Old 08-14-2007, 07:31 PM
Fouler's Avatar
Send a message via MSN to Fouler
I wanna say due to the wattage but I wouldn't be sure i've heard more problems with 50w than 35w versions so it's a toss up.
-Silverfox™
If you want some muscle but don't want to spend the money. Watch This Clip
Don't end up like that just spend the damn money!
Fouler is offline
post #5 of 7 (permalink) Old 08-14-2007, 08:18 PM
elitemazda6's Avatar
Send a message via AIM to elitemazda6 Send a message via MSN to elitemazda6
PMed
elitemazda6 is offline
post #6 of 7 (permalink) Old 08-14-2007, 09:10 PM Thread Starter
Here are some pics of my 55watt 5000K hids
ID:	60131   Click image for larger version
ID:	60132   Click image for larger version
ID:	60133   Click image for larger version
post #7 of 7 (permalink) Old 08-14-2007, 11:10 PM
Looks good
Curious: what fog lights did you go with?
