HID's Install - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 06-11-2007, 12:24 AM Thread Starter
hypnoticblazze's Avatar
Ok so I installed an Apexcone 5000k about a week ago with the glare mod as well, and here are 2 problems I'm having,
1) I have a nice thick blue cutoff on my right side projector, and on the left I have no color at all. I didn't do anything to the cutoff shields, so both my cutoff should be the same with no color at all. I'm going to be doing a retrofit at the end of the summer, but I pretty much got this kit for free, so why not go for it in the mean time. Here is a picture to better show what I'm talking about. I took it with my cell phone, since I'm not home. As soon as I get home I'll get you guys better pictures, for now this will do.
[attachment=25356:0610072324.jpg]
2) Every time I turn my lights on I get interference on my radio. I have the Bose radio and I noticed it when I turned my lights off while I was in my driveway. Its very noticeable interference too. Weird right?
Help!!!
Thanks
2005 Onxy Black 6s
Fujita F5 CAI // Optimized TB // Magnaflow cat-back // 6000k Apexcone 35w HID's in low beams (with glare mod) and integrated fog lights // Piaa clear 194's // Sirius Sporter 5 // Tenzo R's Passion 5 18X7.5 // 225 40 Falken Ziex ZE912 // LED tails // 15% tint all around
hypnoticblazze is offline
post #2 of 11 (permalink) Old 06-11-2007, 06:02 PM
kansasmazda6s's Avatar
I don't know about the color, but the noise is probably the HID ballasts.
kansasmazda6s is offline
post #3 of 11 (permalink) Old 06-12-2007, 02:15 PM
Philter25's Avatar
I also get interference on my radio when I turn my lights on but only when my radio signal is weak. It only happens when I am in the garage.... as soon as I go outside and I have a strong signal, my radio is fine.
Is yours worse than this?
As for the color..... it could be a handful of things..... first guess would be a bad bulb. If it really bothers you, try switching your right and left bulb and see if the color goes with it.... if it does, then its your bulbs.... if not, then try eliminating whats NOT causing the problem.
Philter25 is offline
post #4 of 11 (permalink) Old 06-12-2007, 02:26 PM
06mazdasports's Avatar
How can the interference be the ballasts? the ballasts have no soft of Rf waves coming out of it, so how would it coincide with the radio? Check to see if your wiring is neatly tucked in a safe area and not dangling in the middle of nowhere. Maybe insulate the wiring with duct tape to prevent the interference. Also, do you have an aftermarket antenna?
the lights: I am almost sure your lights are not positioned correctly. If you just dropped the lights in, the right projector tends to "veer off" little to the right, and most likely that blue light is the edge of the projector being pointed straight after you adjusted the lights. So in essence, your lights "look" straight, but measurements wise the projector is NOT straight.
06mazdasports is offline
post #5 of 11 (permalink) Old 06-12-2007, 10:46 PM Thread Starter
As for the color..... it could be a handful of things..... first guess would be a bad bulb. If it really bothers you, try switching your right and left bulb and see if the color goes with it.... if it does, then its your bulbs.... if not, then try eliminating whats NOT causing the problem.[/b]
Yea it is. I'm going to see if it happens once the bulb warms up ... if not then my ballasts might be making noise ... which in turn will interfere with the radio
As for the lights ... I'll try that when I get a chance to take the bumper off again ... as soon as my lower fogs come in ill do that
the lights: I am almost sure your lights are not positioned correctly. If you just dropped the lights in, the right projector tends to "veer off" little to the right, and most likely that blue light is the edge of the projector being pointed straight after you adjusted the lights. So in essence, your lights "look" straight, but measurements wise the projector is NOT straight.[/b]
As for the radio ... no I don't have an aftermarket antenna ... the possibility exists that I may have a loose connection or a wire dangling some where ... all i taped up where the connection into the headlight harness which where the ground and the red wire ... I don't see why the other connections should need tape
As for the lights ... I'm thinking I may have a bad bulb ... If not I may have slightly pushed the cutoff shield when doing the glare mod ... The aiming on them is perfect ... it took me a couple of days to aim them ... and its perfect so I know its not the aim.
2005 Onxy Black 6s
post #6 of 11 (permalink) Old 06-13-2007, 12:35 PM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
The color of your bulbs looks to be different.Almost like the right side has color shifted and the left has not.Also check your adjustment,attached is a pic of how to properly adjust them.Now the radio interference is from the ballasts and is common on 35w ballasts.
2010 F-150
1990 F-150
djquik1 is offline
post #7 of 11 (permalink) Old 06-13-2007, 01:10 PM
speed914's Avatar
Quoted: 6 Post(s)
Send a message via AIM to speed914
one of my bulbs is a diff color than the other too... one almost looks 4500k and the other 6000k.... i haven't been able to get anywhere with this tho... if you have any luck LET ME KNOW!!!
2005 Mazda 6i Sport Glacier Silver ATX
Apexcone 6000k HIDs, PIAA 7500K Spark Blue H3, F5 Fujita Intake, Remote Car Starter, Lotek Gauge Pod, ProSport Premium Series Oil Pressure and Oil Temp Gauge, ProSport Performance Air/Fuel Ratio Gauge, ScanGauge II, CPE battery tray, Odyssey 680, Tein Hood Dampers, grounding kit, clear side markers, Mazda3 2.0l Spin-on Oil Filter conversion, G2Performance Caliper paint, All weather mats, ALL hyper white LEDs, stubby antenna
speed914 is offline
post #8 of 11 (permalink) Old 06-13-2007, 01:47 PM Thread Starter
The color of your bulbs looks to be different.Almost like the right side has color shifted and the left has not.Also check your adjustment,attached is a pic of how to properly adjust them.Now the radio interference is from the ballasts and is common on 35w ballasts.[/b]
The aiming on the photo looks bad because I was only about 10 feet back.
Your right it does look like one of my bulbs is bluer. I'll look into it tonight because I never really noticed that until I payed close attention to the photo. It might be that its due to the photo angle.
2005 Onxy Black 6s
post #9 of 11 (permalink) Old 06-13-2007, 02:08 PM
djquik1's Avatar
Groans: 14
Your right it does look like one of my bulbs is bluer. I'll look into it tonight because I never really noticed that until I payed close attention to the photo. It might be that its due to the photo angle.[/b]
I wasn't talking about adjustment for level.I was refering to the distance between the center of your projectors is not the same as the distance between the steps of your cut off.You may want to look at that.
2010 F-150
1990 F-150
djquik1 is offline
post #10 of 11 (permalink) Old 06-13-2007, 07:55 PM
actually any electrical item wired into your vehicles system will give off a bit of "noise" Commonly referred to as "rpm whine" or "alternator" whine.
Simple fixes, double check grounds. did you make new ones for the Ballasts grounds, or did you just use the factory wiring? I made new ones for my HID's, sanded the paint off and then bolted it nice and tight and shot it with a battery terminal corrosion inhibitor. Check your radios ground as well. Heck while you are at it, check your battery neg to chassis ground.
On mine if I have my radio on and then turn on my lights, I get a pop, and thats it. This is just from the draw the HID's take to power on. But once they fire all is good.
Stealthy-One is offline
