HID's Install - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 11 (permalink) Old 06-13-2007, 11:17 PM Thread Starter
hypnoticblazze's Avatar
actually any electrical item wired into your vehicles system will give off a bit of "noise" Commonly referred to as "rpm whine" or "alternator" whine.
Simple fixes, double check grounds. did you make new ones for the Ballasts grounds, or did you just use the factory wiring? I made new ones for my HID's, sanded the paint off and then bolted it nice and tight and shot it with a battery terminal corrosion inhibitor. Check your radios ground as well. Heck while you are at it, check your battery neg to chassis ground.
On mine if I have my radio on and then turn on my lights, I get a pop, and thats it. This is just from the draw the HID's take to power on. But once they fire all is good.[/b]
How did you give your ballasts a ground? Do the bolts in your ballasts serve as a ground?
2005 Onxy Black 6s
Fujita F5 CAI // Optimized TB // Magnaflow cat-back // 6000k Apexcone 35w HID's in low beams (with glare mod) and integrated fog lights // Piaa clear 194's // Sirius Sporter 5 // Tenzo R's Passion 5 18X7.5 // 225 40 Falken Ziex ZE912 // LED tails // 15% tint all around
hypnoticblazze is offline
