HID glare removal mod, will it affect the lighting?? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 13 (permalink) Old 06-10-2007, 04:09 PM
speedyellow6s
Guest
Posts: n/a
Quoted: Post(s)
Looking to update the car with HID lights, probably the Apexcone 6000k from RPM, but just want to know if the glare removal mod has an affect on the light out put. Meaning will this affect the beam to not project as far as normal?
Thanks
post #2 of 13 (permalink) Old 06-10-2007, 06:18 PM
unfortunately the answer is yes. But it makes you have a retrofit look & doesnt blind oncoming traffic. I also color modded mine, but i wont have pics for another 3 weeks until i get my halo's in.
MikeyD is offline
post #3 of 13 (permalink) Old 06-10-2007, 11:56 PM
hypnoticblazze's Avatar
Actually, light output will not decrease due to the glare removal mod. I did install HIDS and did the glare mod, I will eventually due the retro fit.
The only thing that the glare piece does is take light and reflect it up to light up street signs better. HID's are a whole lot brighter and that glare piece will redirect way too much light upwards and blind oncoming traffic.
Once you remove the piece you can aim the light SLIGHTLY and I repeat SLIGHTLY higher to get the light up of the street signs.
Hope this helps dont forget to post pics
2005 Onxy Black 6s
Fujita F5 CAI // Optimized TB // Magnaflow cat-back // 6000k Apexcone 35w HID's in low beams (with glare mod) and integrated fog lights // Piaa clear 194's // Sirius Sporter 5 // Tenzo R's Passion 5 18X7.5 // 225 40 Falken Ziex ZE912 // LED tails // 15% tint all around
hypnoticblazze is offline
post #4 of 13 (permalink) Old 06-11-2007, 10:09 AM
Hope this helps dont forget to post pics[/b]
what ^ said.
When you remove this peice the light will go from being "bled" upwards, to now directly infront, as to where it should go....that piece is there to bleed the light up from our halogen projectors.
So whenver you do decide to get around to do this... i'd def. recommend you taking the reflective piece out when you have the headlight in hand...because trying to get it off when the lamps are on the car is a PITA...good luck and yes tons of pictures are always appreciated!
FS:
sexy6s is offline
post #5 of 13 (permalink) Old 06-11-2007, 12:01 PM
SANDMAN.3's Avatar
Groans: 19
I have the Apexcone 6000K 50W HID using the stock projectors and no "glare mod" ... it works fine for me. Had it a few months now and so far it work perfectly with no arguments/harassments (flashes, pull-over etc...) whatsoever from other drivers and police. Then again I only had it for a few months.
Just adjust your cutoff according to the legal limits and should have no problems.
I work at night, so It's in use everyday.
SANDMAN.3 is offline
post #6 of 13 (permalink) Old 06-12-2007, 02:03 AM
6 Pack's Avatar
Send a message via MSN to 6 Pack
A halogen projector with a HID Kit bulb is a mis-match . HID bulbs are uniquely made and different from filament Halogen bulbs . HID bulbs are to be accompanied by specially adapted HID projector bowls to reflect light in a superior fashion compared to Halogen in general .
To the untrained eye the WOW factor of a kit is the same for everyone at first , including me . I'm glad I didn't buy into a kit like I thought I should at first . Something inside kept me hesitating too with all I was reading here , despite the fact I hated to have to open up my headlight housings if I chose to retrofit . Today I recieved my TSX projectors from Canada Post
I know of some that went ahead and bought them kits and no later than a few months ; traded them in for True HID projectors . At first it's all ''eye-candy'' but then you realize that bunch of intense hot-spots of mis-directed light in the foreground is too much ; when you can't see past it 'cause your pupils are tightened (like a flashlight in your eyes) ! Very unsafe ! With a true HID projector with its super razor sharp cut-off and evenly smooth beam spread .... you end up seeing the night & day difference .
This is what you should know when it comes to HID Halogen kits (see following link for addtional wisdom)
pics taken from http://www.hidplanet.com/forums/viewtopic.php?t=3505
Disaster pix. HID kit in Halogen Housing
[attachment=25455:Mad_Glar...using_00.jpg]
[attachment=25456:Mad_Glar...using_01.jpg]
This is what HID is suppose to look like.. Pictured is a STi
[attachment=25457:This_is_..._like_00.jpg]
Talk about a Razor Sharp Cutoff. Pictured is a S2000 OEM setup
[attachment=25458:S2000_OE...t_off_00.jpg]
HID KIT vs. True HID
[attachment=25459:HID_Kit_...actor_00.jpg]
[attachment=25460:True_HID...pread_00.jpg]
check out what a "kit" does to stock Neon headlights lol....
Notice the glare and VERY uncontrolled pattern with a bunch of hotspots?
[attachment=25461:HID_Kit_...spots_01.jpg]
ID:	57759   Click image for larger version
ID:	57760   Click image for larger version
ID:	57761   Click image for larger version
ID:	57762   Click image for larger version
ID:	57764   Click image for larger version
6 Pack is offline
post #7 of 13 (permalink) Old 06-12-2007, 11:42 AM
Business's Avatar
instead of posting what they do to a neon's stock headlights, why not show what they do to a 6? obviously retro is the best way to go, but the 6, from what i've seen both from pictures and in person, handles HIDs just fine, without those hotspots and much glare at all. i've always been very impressed with the output and how even it was.
and those disaster pics are just that...disasters on other cars with (likely) a bad install or poor quality HID setup. apples and oranges.
Now rocking a 91 Miata
Business is offline
post #8 of 13 (permalink) Old 06-12-2007, 12:50 PM
SANDMAN.3's Avatar
Groans: 19
and those disaster pics are just that...disasters on other cars with (likely) a bad install or poor quality HID setup. apples and oranges.[/b]
+1
My cutoff from my stock 2003 projectors and aftermarket HID kits are almost flawless and very sharp. Didn't even require to that glare modifictaion mod that so many did.
[attachment=25461:HID_Kit_...spots_01.jpg][/b]
Those are non-projector headlights! ...
To my knowledge... all 6 have projectors and will give you that sharp cutoff... maybe not that "RAZOR SHARP" w/o some additional mods. But still... great cutoff.
post #9 of 13 (permalink) Old 06-13-2007, 11:17 AM
Sullosar's Avatar
Is it possible to install HIDs and do this "glare removal mod" without baking open the headlights? This is the first I've heard of the mod, so don't know how it goes.
Its sad, the main reason I don't get angel eyes is because I have rockblocker tint on my headlights, and it cost $50. I'm pretty sure it'd be screwed if I baked my headlights, and I don't want to waste that money.
Bullet- 2003 Mazda6S- Sport 3.0L MTX Lapis Metallic
Current mods- Injen Cold Air Intake, 20% Tint all around, clear corner lights, blue interior LEDs, blue light up door sills, painted brake calipers, Blue Rockblocker light protection film on headlights and clear corners, True-Euro Clear taillights tinted with Nite-Shades
Wish-List Mods- Mazdaspeed Short Throw Shifter, Racing Beat Sway-Bars & End-Links, CP-E Engine Mounts, Racing Beat Springs with Bilstein HD Shocks
Sullosar is offline
post #10 of 13 (permalink) Old 06-13-2007, 11:28 AM
Business's Avatar
you don't open the headlights for the reflector removal, you just remove them from the car.
Business is offline
