headlights dim when fans kick on - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 03-12-2007, 02:59 AM Thread Starter
indabox's Avatar
Send a message via AIM to indabox Send a message via Yahoo to indabox
just wondering if anyone else has problems with the headlights dimming when the fans come on and when they are rolling the windows up/down...
What are things I can do to fix this?
I have an apexcone 6k HID kit that I havent put in yet. will this go away after I install the kit?
<div align="center">
indabox is offline
post #2 of 10 (permalink) Old 03-12-2007, 08:58 AM
Just wondering what the condition of your battery is like? Cause a lowish charged battery can have this kind of behaviour. How does your car start first thing in the morning? If it starts sluggishly then it is a sign of deterating battery or worse with electrical problem relates to the charging circuitry. Just a suggestion to check.
M6Gr8 is offline
post #3 of 10 (permalink) Old 03-12-2007, 02:49 PM
5isiX's Avatar
Quoted: 13 Post(s)
I am going to go ahead and say that it is most likely a weak battery. How long has it been since you replaced it? My battery is pretty weak right now after the winter and the windows are kinda slow going up sometimes and the lights dim as well. Starting was pretty sluggish too this winter.
Next step would be a bad alternator.
5isiX is offline
post #4 of 10 (permalink) Old 03-12-2007, 03:01 PM
Hmm, how often is recommended for a swap for our batteries?
terigox is offline
post #5 of 10 (permalink) Old 03-12-2007, 07:34 PM Thread Starter
indabox's Avatar
the battery is the one that came with the car, and I have only had it a little over a year. its a 2005 I got in feb of 06 new.
What would be the best to replace it with? the car starts like normal and is not sluggish at all.
I was thinking an optima red or yellow top. anyone have the part numbers for those batteries that fit our car?
indabox is offline
post #6 of 10 (permalink) Old 03-13-2007, 07:32 AM
Mz6GreyGhost's Avatar
Quoted: 840 Post(s)
Groaned at 6 Times in 3 Posts
In other words, that battery is practically brand-new, and there shouldn&#39;t be a problem with it.
Before wasting $$$ on a new battery, take it to an Autozone or Advance Auto (or any other auto parts store) and have the battery tested, just to make sure it&#39;s working properly.
Mz6GreyGhost is offline
post #7 of 10 (permalink) Old 03-18-2007, 03:23 AM
dashrif's Avatar
Your fan controller sensor my be going out I had to replace one
Bone stock 6s atx..... Or is it?
dashrif is offline
post #8 of 10 (permalink) Old 03-18-2007, 05:19 AM
anotherM6's Avatar
i have 2003 6s and my headlights dim for a split second whenever i move my windows up/ down. i dont think its anything major. it happens on my civic as well, so i doubt it has something to do with the battery.
2003 steel grey mazda6s mtx appearance package
anotherM6 is offline
post #9 of 10 (permalink) Old 03-18-2007, 09:04 AM
zoomnbyu's Avatar
Unhappy
This thread is another one of those that makes me say . #1, indabox does not state when this happens (i.e. idling, or when driving) so it&#39;s kind of a pointless question.
Every
car made does this to some degree, especially at idle. It&#39;s just the load hitting your elestrical system before the voltage regulator can adjust - usually taking a whole split second. It&#39;s worse at idle and can dim your lights while under the additional load because the alternator really can&#39;y sustain it&#39;s nominal output until about 1500-2000 rpm&#39;s. You&#39;ll also notice the occassional flicker while driving especially when the AC compressor kicks in because of it&#39;s very high draw as the clutch is engaged.
While you can&#39;t totally discount the battery&#39;s condition based on the lack of info given, a quick trip to your local shop, or parts store can check out everything in about 15 seconds if they have a Midtronics tester.
"Peace! I&#39;m outa here!!!"
No matter where you go, I&#39;ll be zoomnbyu!
zoomnbyu is offline
post #10 of 10 (permalink) Old 03-18-2007, 10:16 AM
dashrif's Avatar
i have 2003 6s and my headlights dim for a split second whenever i move my windows up/ down. i dont think its anything major. it happens on my civic as well, so i doubt it has something to do with the battery.[/b]
+1
But 03- 04 and some 05 6s has had problems with this. In the early stages headlights dim and later the fan gets louder and fails to turn off.
http://forum.mazda6club.com/index.php?show...=headlights+dim
http://forum.mazda6club.com/index.php?show...;hl=fan+control
http://forum.mazda6tech.com/viewtopic.php?t=9
dashrif is offline
