changing the projectors on my 6 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #21 of 23 (permalink) Old 02-26-2007, 11:04 AM
are those top pics the E46 projector with D1S connector/bulbs?
I'm sure the bottom pic will work. The E46's are a direct bolt on, and in Justin's case he was able to mount an E55 bi-xenon projector in there. There isnt a whole lot of room to work with because of the stupid bezel. The projector naturally sits about a half inch to an inch BEHIND the projector, so i'm sure if you trim a bit off you'd be able to fit in just about anything.
The issue comes you'll come across is with the orange bracket that the projector actually mounts up to. The screws proably wont line up so you'll have a little more work if you want to use any other projector other than the E46.
Check out Tim's write up for pictures of the mounting bracket. You can find it at the top (sticky) of the Electrical Section on the Forum. Hope that helps....Good luck.
FS:
sexy6s is offline
post #22 of 23 (permalink) Old 02-26-2007, 02:33 PM
t_mo_t's Avatar
yeah the top one looks like bixenon D1S....
and the projector on the bottom picture will work just fine, except that you need to get different set of ballast, the ballast shown is bosch al gen3, which has that ignitor built into the bulb holder, some member found it to be too bulky and wont let the dust cap close properly IIRC...
t_mo_t is offline
post #23 of 23 (permalink) Old 02-26-2007, 02:39 PM
and the projector on the bottom picture will work just fine, except that you need to get different set of ballast, the ballast shown is bosch al gen3, which has that ignitor built into the bulb holder, some member found it to be too bulky and wont let the dust cap close properly IIRC...[/b]
+1 the bottom one will def. fit. Tim's right, and i agree it is a bit bulky, but i cut around the edge of the dustcap so the wire can slide through, insteadll of right in the middle of the dustcap. just make sure you get up on the sealant though....and you're good to go.
FS:
sexy6s is offline
