Key fob died - where to get replacement? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 02-15-2007, 01:00 PM Thread Starter
All,
I've done some searching on google as well as in these forums and can't find any information as to where to get a new key fob for my 2003 Mazda 6s. If not new, can the battery be replaced?
Can anyone point me in the right direction?
Thanks!
viper8 is offline
post #2 of 11 (permalink) Old 02-15-2007, 01:11 PM
kpjimmy's Avatar
Quoted: 7 Post(s)
As for a key fob are you referring to your car alarm fob? If that is the case, take it to any car audio place to get your battery replaced in the car alarm fob.
But if you are handy, find a tool to uscrew the unit and you can find the battery inside. Take it to your local store, be it target or walmart even, and try to find it there. Oh you can also try camera stores.
Good luck!
Come join the flickr group!
kpjimmy is offline
post #3 of 11 (permalink) Old 02-15-2007, 01:26 PM Thread Starter
Yeah I'm referring to the stock remote key entry fob that came with the car. And thanks!! I got it open and located the 3V battery..will pick up a replacement. I shouldn't have to reprogram it, eh?
Good luck![/b]
viper8 is offline
post #4 of 11 (permalink) Old 02-15-2007, 01:29 PM
kpjimmy's Avatar
Quoted: 7 Post(s)
Nope no reprogramming necessary.
kpjimmy is offline
post #5 of 11 (permalink) Old 02-15-2007, 01:34 PM
Nope no reprogramming necessary.[/b]
My fob died as well, but after replacing the battery, it still doesn't work. Next time I take the car into service I'll have them look at it.
2005 Mazda 6 S MTX Steel Gray sedan-Sport Package, Bose, Moonroof, leather
mods-Under bumper fog lights, lighted door sills, PIAA Extreme White 4000K high beams and H3 fog lights,Avon Tech M550 225/45ZR-17 tires, BR Lip , LED rear brake/tail lights, Apexcone DDM 4500k 35w HIDs in low beams
-mods on hold to save for wife's Miata-PURCHASED MIATA on 12/23/2008. Now the battle is which car gets the next MODs!!!
murago is offline
post #6 of 11 (permalink) Old 02-15-2007, 01:47 PM
kpjimmy's Avatar
Quoted: 7 Post(s)
wow really? I may be wrong. But I am unsure why the fob doesnt work just by replacing the battery. Does anyone know if you have do something additional, ie. disconnect and reconnect the battery?
kpjimmy is offline
post #7 of 11 (permalink) Old 02-15-2007, 02:01 PM Thread Starter
I just ran up to Radio Shack, bought a replacement - popped it in the fob and it worked great the first time!
Thanks
wow really? I may be wrong. But I am unsure why the fob doesnt work just by replacing the battery. Does anyone know if you have do something additional, ie. disconnect and reconnect the battery?[/b]
viper8 is offline
post #8 of 11 (permalink) Old 02-15-2007, 02:33 PM
kpjimmy's Avatar
Quoted: 7 Post(s)
Ah so I was correct! LOL Well thanks for reporting back!
My fob died as well, but after replacing the battery, it still doesn't work. Next time I take the car into service I'll have them look at it.[/b]
I forgot to ask what year you have. Maybe that is a reason?
kpjimmy is offline
post #9 of 11 (permalink) Old 02-15-2007, 02:40 PM
VinDali's Avatar
Sometimes the buttons get messed up too. On my old car, I had to have the Fobs replaced multiple times because the buttons died. Tried new batteries, but no response.
When this happened I returned to the dealer and they just swapped out a good one for the bad one. Just FYI.
2004 Mazda6s Sedan, AT, Lapis Blue, Loaded, Sports Package/sports grill, K&N Air Filter
"I thought I had an appetite for destruction. Turns out all I wanted was a Club Sandwich."
Homer J Simpson
VinDali is offline
post #10 of 11 (permalink) Old 02-15-2007, 10:32 PM
My keyfob died and it was not the battery. I took it apart and they are pretty simple inside just a wee tiny board with a few buttons. I took the battery out and cleaned it with alcohal and a few cotton swabs. Once dried I bent the tiny battery connectors back out so that they would be pushing against the battery better, and popped the battery back in and boom, it works fine now. So ya might try that before you throw it away or replace it.
fullmetal6 is offline
