Relay Clicking Noise every ~30 seconds - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 01-06-2007, 10:13 PM
hokielife
Guest
Posts: n/a
Quoted: Post(s)
Thumbs up
I am new to Mazda's and this 6. I Just got it 3 weeks ago. I notice that when the key is on the second click position (ON) but the car is not started, about every 30 seconds I will hear a relay click under the hood. Radio is off, AC and all lights are off (except the dash lights).
Is this normal?
To get a good idea of what I am hearing, turn your car on (but don't start, let everything click on) Then turn off. When I do this, I hear the relay again, which I assume is normal, the other ones I am not sure.
Thoughts?
---------------Update 2 min later --------------
I read on another forum (Toyota Tundra) that someone else had the same question. Turned out to be normal for his truck. I open the hood and listened and it appears that the throttle body/Mass Air flow sensor area is the source. Still would like to have others confirm this claim. Maybe someone else can use this if they have the same question.
post #2 of 3 (permalink) Old 01-07-2007, 12:37 AM
Matt60158's Avatar
Send a message via AIM to Matt60158
I think I have also heard what you speak off, to my knowledge it is normal as well.
2004 Lapis Blue with a few bolt on's. Everytime you make it home to the garage and close that door it's like a fresh start the next day...
Matt60158 is offline
post #3 of 3 (permalink) Old 01-07-2007, 01:45 AM
Send a message via AIM to ilal2ielli
Yep, its normal, and it is the throttle body. Step on the gas while the ignition is set to ON without the car started and you'll hear the throttle plate move.
ilal2ielli is offline
