Urgent: Installing Gauge Overlays - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 12-24-2006, 02:24 PM Thread Starter
So I'm doing this mod right now but the problem is that I only see two black wires with red stripe and pink stripe but I can't find a perfect black grounding wire. So I'm not sure which one should I tap into.
Any help is appreciated. Thanks.
king_lam925 is offline
post #2 of 6 (permalink) Old 12-24-2006, 03:09 PM Thread Starter
Please...it's getting dark right now.
Everyone is out for Christmas already?
I'm going out soon as well.
post #3 of 6 (permalink) Old 12-24-2006, 03:40 PM
redfire6i's Avatar
Send a message via AIM to redfire6i
You should be able to ground it to anything, if you can find a ground wire for whatever reason, just run a wire to a radio support or something, if you have a multimeter just check different spots for a good ground...Should be easy to find a ground wire though
redfire6i is offline
post #4 of 6 (permalink) Old 12-24-2006, 05:18 PM Thread Starter
Okay I tried. And I'm sure I taped the red wire into the light green wire with red stripe but it won't light up for some reason...
I&#39;m so pissed, I&#39;m gonna drive the car w/o gauge reading but I guess I can tell how fast the car is going by looking at the needles... <_<
Did you guys tap your wires to the turn signal&#39;s power source and solid ground? cuz I found the exact wires that I want...
I just tapped the red wire to the (green & red) wire of the gauge cluster. I don&#39;t know if I&#39;m doing it right. I checked out the How-to pictures and I&#39;m sure that&#39;s the right place.
Any help?
post #5 of 6 (permalink) Old 12-25-2006, 08:55 AM
Iluv2zmzm's Avatar
Groaned at 8 Times in 1 Post
http://forum.mazda6club.com/index.php?show...=gauge+overlays
not sure if this helps
good luck
Iluv2zmzm is offline
post #6 of 6 (permalink) Old 12-25-2006, 05:45 PM Thread Starter
^^^I followed the exact how-to to do the mod. Plus I checked out other threads before I did my own.
I&#39;ll get some pictures tomorrow so that you guys can point out what the problem is.
