Has anyone replaced their flasher? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 25 (permalink) Old 12-11-2006, 11:20 PM Thread Starter
Send a message via Yahoo to Tazz2000
Was wanting to know if anyone has replaced their blinker flasher when installing LEDS?
I'm not even sure where the flasher is, i'm thinking it is inside by the fuse box, but was wondering what kind you used and where you got it.
Thanks,
Tazz2000 is offline
post #2 of 25 (permalink) Old 12-12-2006, 09:23 PM
t_mo_t's Avatar
+1
hmm this is what i was wondering too.. our flasher is located behind the speedometer IIRC...
bump for the question!!
t_mo_t is offline
post #3 of 25 (permalink) Old 12-12-2006, 09:58 PM
redfire6i's Avatar
Send a message via AIM to redfire6i
I found this on directed's website, dont know if this would work or not because im not sure what your trying to do.
Light Flasher Assmbley
redfire6i is offline
post #4 of 25 (permalink) Old 12-13-2006, 01:16 AM Thread Starter
I was thinking about changing out the turns with LEDS, means you would either have to use resistors or an
electronic flasher unit.
Tazz2000 is offline
post #5 of 25 (permalink) Old 12-13-2006, 02:46 AM
Mazda Gremlyn's Avatar
autolumination.com has the resistor kits.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #6 of 25 (permalink) Old 12-13-2006, 07:16 AM
t_mo_t's Avatar
well IIRC, the load resistor will get very hot during use, and you have to buy at least 2 if you are going to change your turn signal LEDs front and back, and you have to think about the safest mounting location... but if you have the flasher, you just have to replace your stock flasher to the new flasher that wont make the LEDs blink so fast.... so i would prefer the flasher myself...
lol, although it's kinda similar, but this is what we're talking abt
http://superbrightleds.com/flashers.htm
and picking the right one for our car, is the question.
ELECTRONIC LED FLASHERS
We now offer 2-Pin and 3-Pin (1/4 inch spade lug type) LED compatible Flasher Units in this category
You should definitely use one of these instead of Load Resistors if we have one to fit your vehicle
They operate at the correct flash rate with LED or standard filament bulbs
10~15 Volts DC - Flash Rate: 80 per minute
Note that some of these flashers operate silently, they do not make the familiar clicking sound when operating. One solution is to connect a common automotive relay to the output along with your LED bulbs
Also note that these flashers do not replace all flasher units. Before you order, please see the pin outs of our flashers in the table below and compare with the one you are replacing. Click the part numbers for complete spec sheets. You can usually find your flasher pin out printed right on your flasher. Failure to check this and installation in an incompatible vehicle can blow your fuse, destroy the flasher and void the flasher warranty
t_mo_t is offline
post #7 of 25 (permalink) Old 12-13-2006, 11:42 AM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
I have already gone this route and ordered in a stock flasher to try and match it up with the chart on superbrightleds website and they do not have one availible yet.They do not have one on the market in the US.there may be some overseas but i haven't had time to look for them yet.
2010 F-150
1990 F-150
djquik1 is offline
post #8 of 25 (permalink) Old 12-15-2006, 06:21 AM
Send a message via AIM to cbob
stupid question, think the answer is yes.
Anyway, I don't want/care for LED bulbs. However, flasher click does bug me at times, esp at a long light and it's just clicky clicking away. So, if we found a flasher that worked and didn't click I could just pop it in?
03 6i MTX. 215/55-16 Kumho ASX, EBC green stuff, custom scored/fracturing rotors. Gutted airbox, crank mod, RPM short throw adapter, 2wheelin's fan mod. Sylfex aux-mod, concealed XM install, brake light mod, Redline 75w-90, Redline water wetter, and speed bleeders.
a half dozen UOAs. Currently on ~10k OCI.
suspect vacuum leak issue.
Note to self: no more adjustable wrenches.
cbob is offline
post #9 of 25 (permalink) Old 12-19-2006, 12:43 AM Thread Starter
I have not been able to find one that will replace ours, thats the reason for the question.
I'm looking to replace my rear brakes, turns and reverse with LED PCB Boards. I don't want to use resistors because of the heat.
cbob,
I'm glad you don't care about LEDS, but you would like to find a quieter one , electronic flasher units don't make noise.
So I guess not a stupid question, just a stupid response!
Tazz2000 is offline
post #10 of 25 (permalink) Old 12-19-2006, 02:23 AM
t_mo_t's Avatar
Yo dj, can you take a picture of the flasher unit for us? so we know what to look for? Thanks man!
cbob,
you dont need flasher for rear brakes, and reverse... just for the turn signal light... yepp.. i dont want to install load eq. as well, as it produces heat... too much heat... well it's easy to solve by getting a heat sink and all, but the space it takes inside the engine bay, i'd rather have a small flasher unit which is not visible....
t_mo_t is offline
