Electrical mod.. warranty = plfft? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 11-28-2006, 01:00 AM Thread Starter
So, I spliced into my cigarette lighter to install some cold cathodes under my dash and seats. I was just curious but my warranty would probably be voided if the dealer saw that huh?
I was thinking of getting the reflash but am not sure if I should take those out first. I am guessing they just use the plug under the drivers side to flash it?
* CPE 3" DP * Corksport Dual 3" Catback * MSCAI * SURE TIH * CPE FMIC * Cobb AccessPort Stage2+DoobySelfTune * TT Front Engine Mount * StreetUnit Rear Engine Mount * Autotech HPFP Internals * CPE Rear Diff Mount * Corksport Rear Sway Bar * 20% Tint * Denso ITV22 Spark Plugs * PowerSlot Rotors * EBC RedStuff Pads * TechniFit SS Brake Lines * ATE Super Blue DOT4 Brake Fluid * Amsoil SVG EG and Trans API GL4 Fluids
Dooby is offline
post #2 of 5 (permalink) Old 11-28-2006, 01:03 AM
ryceboi's Avatar
um, your warranty should be fine. unless your mod all of a sudden shorts your ECU and they can prove it, then you have nothing to worry about.
ryceboi is offline
post #3 of 5 (permalink) Old 11-28-2006, 01:08 AM Thread Starter
Ah ok.. falls along the same lines as performance parts then
Dooby is offline
post #4 of 5 (permalink) Old 11-28-2006, 07:10 AM
IrateSpeed6's Avatar
Send a message via AIM to IrateSpeed6 Send a message via Yahoo to IrateSpeed6
does that include a boost gauge? I thought I read somewhere that people were getting voided warranties for boost gauges. (tried searching)
2006 Mazdaspeed 6 - New DD
2002 TA WS6 - 430+rwhp brute
IrateSpeed6 is offline
post #5 of 5 (permalink) Old 11-29-2006, 09:28 AM
No freaking way a boost guage should cause warranty issues...
dbc112 is offline
